Results 1 to 10 of 21
Thread: Power to Rear Anderson Plug to charge trailer battery
    Melbourne, Australia
    I need to get power to an Anderson plug at the rear of the vehicle without running another cable.
    I currently have a 13mm cable running from my main battery through a Traxide SC80 and along the RH chassis rail to my second battery in the rear of the vehicle. I was thinking of tapping into this cable to power the Anderson plug.
    I'm not sure how to do this - can anyone give me some ideas?
    Franz
    Queensland
    Hi Franz and your idea is the simplest way to achieve what you are after.
    Just make sure you take your positive connecting for the rear cable at the cable side of the circuit breaker at the rear battery, not the battery side, or you will need another circuit breaker.
    This diagram should help you.
    NOTE, this is an old diagram and all circuit breakers should be 50 amp
    MarknDeb Guest
    Gday, I personally would not tap into anything their I would run a new line ' I ran 12V Battery Isolator, 4 Post, 60 Amp | Caravan Switches & Relays | CaravansPlus (this is mounted L/H side under the bonnet against the side guard and have a manual switch on the dash I will be changing to a auto switch when iam reading to go camping again) a 30Amp Circuit Breaker Automatic Reset
    Thanks Tim.
    I think my circuit breaker is mounted between the main battery and the SC80.
    I'm unsure as to how to splice into the cable and get a good clean connection though. Cutting, joining & soldering is all I can think of but my soldering skills are so bad I'd rather try for a better, cleaner connection solution.
    Franz
    Tassie/Perth
    Go from your second battery and put a 50A circuit breaker in-line as close to the positive terminal as you can. Keep using a minimum of a 13mm cable and it'll be fine.
    There's no need to have a switching mechanism/controller as you've already got that fitted between the main & secondary battery.
    There is thoughts in regards to dissimilar batteries being connected together without a controller, but I'll leave that discussion for someone else.
    May 2012
    Adelaide Hills, SA
    Do you need to splice?
    Hi Franz, do you really need to splice into the cable, what length of cable are you saving by doing this if your battery is in the back already?
    If you do want to join the cables there may be a fitting available that could clamp around the bared cable, just remember to ensure it is well insulated afterwards.
    Alternately, cut the cable, attach terminals at the cut and the new cable ends and fit in a junction box.
    Good luck
    Mike
    Queensland
    Quote Originally Posted by Franz View Post
    Hi again Franz and you SHOULD have a second circuit breaker, for safety reasons, at the rear battery.
    If you don’t, then you need to fit on and then use it as the junction for your new positive cable you want to run to the Anderson plug.
    The negative for your new cable can come directly off the rear battery’s negative ( - ) terminal.
    Avoca Beach
    You can buy gold plated distribution blocks from Jaycar which have 2x4B&S in one end and 4X8B&S in the other.
    All you do is cut and bare and the cables are held in securely by allen screws. I have been using these for years with no problem, and they have lots of spare taps for 8B&s to run more plugs etc as required.
    Regards Philip A
    Queensland
    Quote Originally Posted by nismine01 View Post
    Good luck
    Mike
    Hi Philip,
    I have a positive cable running from my main battery, through a circuit breaker, SC80 controller, along the chassis to my second battery which is located in the RHR storage bin. The second battery is earthed to the D Pillar earth point.
    I'm trying to avoid running a cable from the second battery on the inside as it's another potential source of dust ingress and would therefor like to tap into the + cable before it enters the vehicle.
    I'll have a look at the gold plated distribution blocks at Jaycar - hope they are available for the 6 B&S cable that I have used.
    Thanks for the info.
    Franz
