Results 1 to 10 of 13
Thread: Recovery gear.
    Jan 2013
    Jervis Bay
    Recovery gear.
    Can someone recommend good recovery gear that doesn't break the bank, I'm looking for a winch accessory kit for the D2.
    Thanks.
    Feb 2005
    most of mine come from ARB years ago........my thoughts at the time were go with good quality, these days its a pretty competitive market and hard to determine quality
    i have the following
    tree protector
    snatch block
    length of chain
    snatch strap
    4 bow shackles
    long handle shovel
    Oct 2007
    wetherill park
    Providing anything you buy has the Australian standards tag it should be ok you can look at tigerz11 and supercheap and pick what you want at reasonable prices.
    For winch recovery look at
    gloves
    winch extension strap
    4 D shackles 8t not 4t
    tree protector
    equalizer strap
    pully block
    and a long shovel
    Then head out to monkey gum and try and get stuck
    Apr 2010
    Connolly, WA
    Quote Originally Posted by Disco_Rock View Post
    Thanks.
    You don't need a "full" kit to start with, and I would personally recommend buying the best quality you can afford even if you buy it over a couple of months. The shovel is always a good starting point because a bit of shoveling will make any recovery a lot easier.
    Keeping and storing any recovery gear correctly will allow it to be used safely for 10 or more years, so look at it as an investment.
    I agree with the list below and I would suggest the following sequence if you are going to build a kit up (not buy it all at once).
    1. Tree Protector
    2. Bow Shackles x 2 (8 ton as suggested)
    3. Winch Blanket (especially if you're using wire rope)
    4. Pulley Block
    5. Equalizer Bridle
    6. D Shackles x 2 to suit your own recovery points (8 ton as suggested)
    Chain is heavy and difficult to handle, especially when covered in mud and I've not carried one of those in many year now...
    Lou
    Barmera .SA.
    Don't forget a next door neighbour with a 4WD.
    Mine came in very handy today as I got the new (to me) Disco nicely bogged down to the diffs.
    So, next thing on my shopping list is a good snatch strap, and some good traction plates.
    And a good solid ground anchor is also a boon. Were no trees where I got bogged down.
    I agree with all the rest of the gear too, winches are pretty easy to buy these days, even a good "comealong" will work in a pinch, just means more manual labour to get yourself out.
    Maybe a couple of good strong manilla ropes, with soft eyes spliced into each end.
    And shackles, lots of strong 8T shackles, I always seem to lose the pins for mine.
    Feb 2010
    Still struggling to break some Aldi winch extension straps myself. It was a little short but two work a treat which is great as they are never coming apart
    You can use rolled up news paper instead of shackles and this will not take your head off like a shackle could if thing go pear shape
    Thread the eye of extension strap through both eyes of your tree protector, put the eye over the extension strap then pull a loop of the extension strap though the eye of the extension strap. Put a rolled up magazine or thick rolled up news paper between the eye and the loop and pull the strap back through the eye until the rolled up paper locks the lot for you. Saw this on a 4wd show- funny as but it does work.
    I think Mud Terrain tires are the bees knees myself and my winch is not used as often as when I was on AT tires. A good shovel is a must as is tire deflator and compressor too.
    Warragul, Victoria
    Can I ask why you are recommending 8 Tonne Shackles?
    Seems to be overkill to me....
    Torres Straits
    Forget the winch extension just get
    200m of 12mm dyneema
    Oh okay start with a 30 or better still a couple of hanks of 30 then work upwards
    Dont need to be fancy terminated ones just seal the ends with a hot knife.
    Tie a bowline - load it to the max then enjoy the wonder of watching a knot be untied in woven rope
    Dyneema is so light and strong I would never both with strap winch extensions any more.
    Especially if you end up in tea tree country and need to make some yards
    And as above - in any good recovery you will always lose a shackle or a pin. Replace the lost one with two and build up a collection of eight or more
    Steve
    Apr 2010
    Connolly, WA
    Quote Originally Posted by Hymie View Post
    Hymie,
    If all shackle ratings were uniform with test certificates issued on purchase over and above the moulded or stamped "rating" I would agree with you. "Ratings" on shackles have been discussed at length here and considering the small the size and relative price difference, it is just prudent to err on the safe side.
    No hard and fast rules, just advice.
    Lou
    Near Seven Hills, Sydney
    Quote Originally Posted by Loubrey View Post
    Hymie,
    Lou
    Make sure your shackles fit with your recovery points! I had swivel recovery eyes on my previous tube bar that would only take ~3.5 tonne shackles.
