13th June 2013, 02:43 PM
td5 boost
I'm trying to find out how much boost is to much. Just put a boost gauge in and it reads 27lb,I do have a chip,intercooler,egr blank,on my td5.Is the amount of boost to high? Gavin
13th June 2013, 05:38 PM
Mine is chipped and peaks at 18psi.Yours should go well,but for how long?
13th June 2013, 05:42 PM
In a word, "yes"!!. You need to back the wastegate off, i.e. wind the nut toward the back of the engine, until you get a good 18-20 psi on a WOT. Have you got an overboost box? You realy need one if you don't. Gee, it must have gone like a scalded cat on 27!!!!.
Robbo
13th June 2013, 06:57 PM
#4
Yes I have a boost box,does go hard. I've done about 3000 ks since the work,mostly towing between 3 & 4 tonn. I was wondering if I'm doing any damage
13th June 2013, 07:14 PM
#5
Where is your boost gauge plumbed in?
13th June 2013, 07:34 PM
#6
13th June 2013, 07:35 PM
#7
First gauge was a cheap eBay one,that read 35, new one is a autometre one
13th June 2013, 08:08 PM
#8
Is this on your D2 or a Defender?
I will explain once you answer...
13th June 2013, 08:22 PM
#9
