6 years, still going strong. Used nearly every day. Hope I haven't jinxed myself.
 Master
						Master
						How long have other puma owners got out of their original batteries? Mine is 3 years old and my original battery if left in the shed for 3-4 days drops down to 12.3 volts - is it needing replacing yet?? Never seems to charge up beyond 12.6 volts. I have had it on my CTEK charger for a few days to make sure its fully charged - no difference, still drops off when left in the shed. Thanks in advance.
 Master
						Master
OEM battery dead after 2 years. Replaced under warranty.
Mine lasted just over 3 years.....
6 years and good as gold.
2007 Defender 110
1993 BMW R100LT
My son's puma battery was replaced just before vehicle was out of warranty,almost 3 yrs old.
Since then he has been having intermittent battery trouble,eventually located the terminals were not tightened correctly when it was changed.
i wouldn't worry about 12.3V after 3 to 4 days.
My D4 battery after 3 to 4 days is often on 11.9V,haven't had any starting issues yet(touch wood)
Geez,some of you guys have had a good run at 6yrs.
3.5 years before I replaced it with Odysseys - still running my work lights just fine...
5 years for original puma battery but it is wired in parallel with another battery.
Car sometimes sits for upto 3 weeks unused and voltage is usually still above 12.6v
I sometimes think about pulling the batteries and and charging them but as yet have not bothered.
HTH
John D - Defender 110 2.4
Close to 6 years and still no indication of it tapering off.
