Well, I just bought a set of Maxtrax. Might have been a good thing, although as you say, they could have been used improperly.
Just got sent the attached photo. These 'Tredz' were apparently used in a 4x4 training day. Whilst info is missing regarding whether they were misused, I'm glad I have Maxtrax! I can't imagine how Maxtrax could ever break like that...
Spin your wheels on any of these plastic track thingies and they will melt and eventually end up like this, regards Frank.
I have seen maxtrax break like that also in an application involving muddy tracks, and an attempt to diagonally load the maxtrax to climb out of a rut. They just snap.
I still went and bought 2 sets though as when used and not abused they are a good bit of kit.
Maxtrax even have moulded into them "read instructions"
Cheers, Davo.
Yes, I've seen those pics too and the guy is a fair dinkum trainer, so I'd respect his experience and opinion.
So, I guess the key is whether the thing is either stiff enough not to bend, or pliable enough to bend without breaking.
You see the steel 'bridgies' used in England which I assume are supposed to be too strong to break.
Can a plastic/poly thing like a Maxtrack or Tred be made either soft enough to bend without breaking or hard enough not to bend under any likely circumstances? I don't know.
4wd TV the other week used a set of Tredz's to bridge a hole in a bridge. 4 or 5 vehicles went over them, they were a bit bent when finished but still in usuable condition. They clearly stated several times that they are not to be used this way and void any warranty and not recommended by Tredz's.
