Results 1 to 10 of 19
Thread: Thoroughly not modern Millicent
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    My 49 built 50 model 80" that i have named Millicent
    Chassis Number R06101688
    vehicle R06101688 was dispatched 'In' 13/09/1949 and dispatched 'out' on 11/10/1949 to Annand and Thompson, Newstead, Brisbane.
    It was in a batch of 44 vehicles and just before the CKD stage so all were assembled in England, including yours apart from, R06101685 and R06101686 which were CKD's and obviously some sort of trial pair as CKD's were away usually in lots of 6. So it would have been dark green, no doubt about that.
    lights thru the grill
    Engine Number 57101979
    1955 2 litre Spread-bore
    Wide transom and sprung seat mounts
    She has finally made it to AULRO Central, all be it in a few bits but she is here.
    I plan to do a rebuild, not a concourse restoration this time round as i don't have the money or the time. I would like to have her on the road for October 2014 when she will be 65 i believe.
    when bought by her previous owner a few years ago from Bundaberg she looked like this
    millicent1hdrweb by NiknoDave, on Flickr
    when she arrived here the other day she looked like this
    millicent on truck by NiknoDave, on Flickr
    now she waits patiently in the corner while i acquire the rest of the bits to rebuild her they way i want.
    20130614_090921(dbc) by NiknoDave, on Flickr
    millicent-in-shed-3 by NiknoDave, on Flickr
    I have been collecting the bits to get her back looking like she should and have acquired a few of the harder to get bits in the last few weeks, much to my wife's dismay.
    I got these a few weeks ago
    Millicent's grill by NiknoDave, on Flickr
    I was given two of the spade back seats and spring mounts a few weeks ago by perry, thanks muchly!
    seatbacks1 by NiknoDave, on Flickr
    seatbacks2 by NiknoDave, on Flickr
    seatbacks3 by NiknoDave, on Flickr
    and then i acquired a 1949 solex yesterday
    carby1 by NiknoDave, on Flickr
    i still have a few things to find including the correct steering wheel and center, the lights to go behind the grill and a few smaller things.
    hoping to get serious with her in the next few weeks.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Aug 2008
    latrobe valley victoria
    the paint in the first pic makes me cringe
    looks pretty good ckd'd in youre shed
    2002 defender 110 , 1955 86 inch
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    first thing i will be getting stuck into is the firewall. it has a rusty top and severe cracking where the steering box bolts up.
    i have a donor firewall that is good where i need it to be so i will be cutting it up to get the bits i need to get millicent's back on deck.
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    more trinkets...
    sparky1 by NiknoDave, on Flickr
    214262 Spark Plug Cover and Sparkmaster L630 Suppressor
    x4
    numpty's Avatar
    numpty is offline TopicToaster Silver Subscriber
    Nundle
    I found the other seat back that I thought I had Dave It's also yours when I can get it to you.
    Numpty
    REMLR No 143
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    Quote Originally Posted by numpty View Post
    much appreciated perry!
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    i had a couple of hours to myself this afternoon so i spent some time checking out the condition of the firewall and pondering ways to repair it.
    it has bad rust under where the windscreen rubber lay, so i set about stabilising it till i can repair it. Had to scrape off heaps of old silicone and some other sort of sealant to get a decent look at it and it is a tad worse than i expected. i wire brushed it and then drowned it in ranex rust converter and have left it to dry. will give it another dose during the week and then empty a can or two of red oxide over it.
    firewall-rust by NiknoDave, on Flickr
    if i can get something like this folded up (but with a rounded edge on the top fold), i reckon the top of the firewall will be a bit easier to get sorted. just have to find out what thickness the firewall is, tho it seems to be about .8mm thick and the folded section would need to be just under 1.6m long.
    will ring a couple of local sheet metal shops to see if it is possible to get done locally.
    i have another 80" firewall from the era that i was hoping to use to replace the fractured steering box support bracket but alas it has been modified to take the later steering box. the things you don't notice
    Current Bracket
    firewall-steerbracket by NiknoDave, on Flickr
    Modified Bracket
    firewall-latersteerbracket by NiknoDave, on Flickr
    anyone have a decent dry 50 model firewall laying around they are interested in parting with or a firewall with the drivers side steering box support bracket intact?
    anyone want what appears to be a 51 firewall with a modified bracket in good nick, good top section but with some rusty bits lower down?
    Queensland
    Quote Originally Posted by incisor View Post
    [insert pic of rusty top on firewall]
    [insert pics of modified support bracket.]
    Cant see the pics but you can have this one if it has the part you need.
    Keith
    Aug 2011
    Albany WA
    Dave,
    Your modified steering bracket would easily removed from the good bulkhead with the use of a 1mm cutting disk on an angle grinder and cleaned up with care and patience , you would hardly know it was ever there.
    Steve
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    Quote Originally Posted by klonk View Post
    Dave,
    Steve
    true, but at the time i thought it a shame to destroy it as it may be handy for someone not wanting to stay with the original steering box
    will see how we get on..
