Results 1 to 4 of 4
Thread: 300tdi New radiator, water pump and p gasket
    mcconnell44 Guest
    Hi everyone,
    I am planning in the next few weeks to replace the radiator (which is knackered), water pump and p gasket in my 300tdi defender, I have been lucky 250,000k's and no dramas so far but I am doing these jobs before something does go wrong and especially while I'm doing the radiator.
    I was wondering while I am replacing these parts is there anything else I can do to make life easier down the track?
    Also are you meant to use a sealant on the p gasket and water pump gasket?
    Would you advise putting copper grease or something similar on the ends of the bolts when i do everything back up?
    Thanks,
    Shane.
    Nanny state UK...
    Sealant not required but worth cleaning up the bolts & using a dab of copper grease.
    M
    Mar 2007
    Tamworth
    Quote Originally Posted by mcconnell44 View Post
    Hi everyone,
    Thanks,
    Shane.
    I really recommend Loctite 518 gasket sealant on both! Although it is not necessary on the paper water pump gasket, I really recommend using it on the "P" gasket as it will definitely not leak, and you will not be pulling it off again! !
    Dec 2010
    cairns
    p gasket &radiator
    hi when I did my radiator I got a extra cooling row in, water pump and p gasket used aviation sealer both sides of gaskets make sure you clean the mating surfaces well, also replaced all hoses, fitted a vdo temp gauge been about 60000ks now pulled a ton and a half camper with tools around aus for three years
    temp gauge sits around 80 or just under half on the old gauge
    also used a torque wrench where I could hope this helps cheers.
