Results 1 to 10 of 23
Thread: chimney flue sweep
    May 2006
    Ulverstone,TAS
    chimney flue sweep
    Hi all,
    Am wondering if anyone has had there flue swept and or if they could recommend someone in the Penrith - Blue mountains area.
    Would like to get mine cleaned before the winter chill arrives.Yeah I know should have done it before..
    cheersa
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    Aug 2012
    North west Sydney
    Hi,
    We've regularly used a guy (Glenn) from Kellyville and found him to be reasonably priced and will be there when he says he will. I'll PM you his contact number.
    regards,
    Mike
    Ellendale Tasmania.
    We just went through this ourselves, I say do it yourself if you can, it's easy, and quicker, we had to replace the bend in our flue as it collapsed, after numerous calls to chimney sweeps who were either too busy or wouldn't come out, we gave up.
    So we decided to do it ourseleves, pulled the fire out, replaced the bend section, put the fire back in, then got up on the roof, took the top cap off the flue , poked the brush down the flue, up and down and turn the brush in a circular motion, 10min done, we used a cobweb brush on an extention pole, all up with taking the fire out from the open fireplace(I'm assuming your fire may be different), about an hour, our flue goes up an excisting chimney and why we need the two bends, it would be even easier if your flue went straight up.
    Cost was $61 for the two stainless steel 45deg bends.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    May 2006
    Ulverstone,TAS
    Hi Redback,
    I've got a combustion fireplace,had an open fireplace at my old place,prefer combustion tho,heats up better.
    Moruya Heads/Sth. Coast, NSW
    Be careful folks, that dust consists mainly of Formaldehyde and Creosote, both extreme Carcinogens, make sure you vacuum up all around the fireplace, Regards Frank.
    Ellendale Tasmania.
    Quote Originally Posted by disco gazza View Post
    Hi Redback,
    That's what we have too, a Conara combustion fire, the flue goes up inside of the chimney of the open (now dissused) fireplace.
    Frank exactly what we did, vacuumed it all up with our Dyson
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Apr 2013
    NSW, Sydney
    Quote Originally Posted by Tank View Post
    If you go down the DIY path, in addition to the long term killers dangers that Frank pointed out, anything short of sealing the bottom of the chimney off with plastic and tape while cleaning will result in a certain and instant death inflicted by SWMBO when she sees the mess you have made...
    You have been warned!
    Mar 2007
    South Arm, Tasmania
    Quote Originally Posted by FeatherWeightDriver View Post
    Wasn't exactly from cleaning the chimney .....................
    but our place in Kalgoorlie originally had an open fire in the loungeroom with a brick arch at the top of the opening. I went out and purchased a rather large combustion heater to slot into the opening. I had measured the width and depth of the fireplace, and assumed that height would not be a problem, as it was a pretty high fireplace. Did not allow for the "arch" encroaching into the top of the opening as far as it did - and the new combustion heater wouldn't fit.
    No problem - out to the shed to get the 9" angle grinder (as you do) and fitted a masonry disk into it. Marked up the two corners that I needed to cut out to fit the heater, and then cut through the bricks and masonry with the 9" grinder - took all of about 10 seconds per corner.
    Hadn't considered where all the brick / masonry dust would end up, so no covers / vaccuum cleaner at the ready. Suffice to say that I would never consider cleaning out a chimney without drop sheets, a good seal around the fireplace and a decent vaccuum cleaner at the ready - I learnt my lesson the hard way.
    Cheers .........
    BMKAL
    Mar 2007
    South Arm, Tasmania
    As for the best way to clean your chimney ......................
    1. Fix long haired tabby in "tabby-tote" carrier (below).
    2. Dip tabby in strong starch solution (to stiffen up "bristles").
    3. Hang tabby, still in "tabby-tote" and allow to dry.
    4. Once tabby is dry and all drop sheets / vaccuum cleaner etc in place, remove cap from top of chimney and feed tabby down the hole.
    Cheers .........
    BMKAL
    WA
    Be careful folks, that dust consists mainly of Formaldehyde and Creosote, ...
    Creosote yes, formaldehyde no (it is a gas, so not much will be able to adsorb onto the soot). However there are lots of other nasties, such as PAHs like benzo(a)pyrene, etc...
    Chimney sweeps in England were one of the first links found between occupational exposures and cancer. However that was chimneys mainly burning coal. The most recent study was from sweden which found higher rates of lung cancer and heart disease in chimney sweeps.
