Results 1 to 9 of 9
Thread: D3 lowers once switched off?
    Jun 2013
    Hi all
    Only had the car two days!!!
    So many questions in these early days - sorry!
    Ive noticed a couple of times that once the car is switched off and I have got out and locked the doors the car lowers very slightly. It was turned off in 'Standard' height. The car definately drops, its noticed by sight and by the sound of air being released from the suspension. It does not drop all the way to access height and does not do it every time??? Any idea's??
    D3 2005 V8
    Aug 2010
    Yes the car self levels, only a small amount though.
    You only have an issue if a corner or end drops. Sometimes if this happens the car will still self level down every so often down to the bump stops.
    2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
    NavyDiver's Avatar
    NavyDiver is offline Very Very Lucky! Gold Subscriber
    Feb 2010
    Quote Originally Posted by Diverre View Post
    Hi all
    D3 2005 V8
    My kids call mine 'Grandpa' who is also known as 'Grandpa pop off' for the bit of wind he emits. Yours sounds like it should be no stress and just auto leveling settling when the engine is started as Rich said.
    Jun 2013
    Quote Originally Posted by ~Rich~ View Post
    I have looked through the manual and not found that bit of info. Why would it do that? Therfore should it not be level just before I have turned it off?
    NSW SW Slopes
    It was level before you got out but then you removed some weight so it had to re-level.
    Jun 2013
    Of course! The weight being me!!!! DOH. Sometimes I don't quite join all the dots)
    Apr 2011
    Coffs Harbour
    It is the joy of owning a vehicle with a bit of character
    2012 Fuji White 3.0 D4, Rear view camera, Hi-line sound, E-diff, Xenon lights, ARB winch bar, Lightforce 240 50w HID. Brads sliders.
    2beFree Guest
    Could be set to "Access Hight". means yours is actually working if in that setting
    Feb 2011
    Floreat (Perth), WA
    Settling after switch-off
    Don't worry about it - our D3 has been doing that for the whole time we've owned it and we've never had any issues with the suspension. I rather like the little sigh as it settles down for the night ...
