                                                2nd July 2013, 06:09 PM
			Wheel studs
					I broke a wheel stud on my FL2 and the studs are not available as just a part, only new hub.
 After much searching have found a VE commodore wheel stud is close enough and does the job. A VE one is approx 5mm shorter in the thread and you have to remove the rim locating tip off it.
 Its still not a simple job though, its press the hub apart to fit.
 Hope this helps someone else that has a broken stud and would like a cheaper option than a whole hub.
                                                15th July 2013, 05:38 PM
					Studs are are also the same as ford kuga.
                                                24th November 2013, 08:44 PM
			Land Rover Rip-off
					I wanted to replace one stud (stripped thread) and was quoted $700 supply and fit new front hub. This is bloody ridiculous when studs are only a couple of dollars at best - would greatly appreciate any help on year/model to fit 2012 SD4 SE Freelander 2.
                                                25th November 2013, 08:53 AM
                                                #4
					this is the one I used.
 Holden Commodore VE Wheel Stud FOR THE Front Rear 14mm X 1 5mm | eBay
 I have a 07 but the hub assembly is the same for all year models
