Results 1 to 9 of 9
Thread: Few question re new D4, please help.
    Bleach8 Guest
    Picked up my D4 last week, it is a very capable car. but I have a few questions I wish someone here can assist:
    1. The front ‘passenger airbag off’ light is on for a few seconds every time I start the car and then goes off. Is this normal? By reading the manual, I seem to think this indicate that the passenger airbag is off.
    Does this happen to your D4?
    2. I noticed a bit of engine noise, like a metal scathing sound, when I accelerate hard or go up a hill. Is this normal for diesel engines?
    Dec 2012
    Adelaide, SA
    2.7 or 3.0?
    The airbag light is a normal thing at startup - as long as it doesn't stay on.
    In answer to your other question, while the diesels are great, they're still diesels and have a small amount of clatter on acceleration along with a soft whistle from the turbo(s). It's normal. Apparently there is a bit less clatter with the 3.0.
    Bleach8 Guest
    its 3.0. its not that bad, just not use to it.
    JamesH Guest
    I don't hear anything under load that isn't awesome*, but as Rich says, it's a diesel and sings in a different accent.
    (Last car was a 300Tdi Defender and Ive long learned to love the reassuring rattle of a diesel)
    Sep 2012
    You can definitely hear the turbo in the 3.0, but not much clatter.
    And the airbag light is normal; if it stays on, you might have disabled the airbag for front baby capsule.
    SBD4's Avatar
    SBD4 is offline A Keeper of the TGO Gold Subscriber
    Dec 2011
    Bundeena
    Quote Originally Posted by phl View Post
    I believe only earlier models had the ability to turn of the air bag. The later ones had this feature deleted as it is not compliant with ADR's.
    Sean
    Sep 2012
    Quote Originally Posted by SBD4 View Post
    IIRC it's a key operated mechanism at the end of the dash, which is hidden by the passenger door when close. I think I took a look when I got the car home a few months ago (MY13); not sure if it will be deleted in MY14, but that's not out yet.
    Edit: Mea culpa; checked today, and the area is blanked in the MY13. The loom is still there, but no switch.
    Is not on my 07 RRS - stickers are there but not the activating key mechanism.
    aliam Guest
    With regards to the passenger air bag light, I asked the same question when picking up my new D4, the sales guy informed me this was normal and the system was going through a check. I would be concerned if it stays illuminated.
    Not too sure about your engine noise, mine is quite apart from the usual turbo whine. Quite impressed how quite the engine is.
