Depends how it's been maintained I guess. I bought a 94 last year to build into a tourer and I replaced all hoses, belts and pretty much anything that was bolted to the engine. It was all knackered. Also did swivels, bearings, shocks and all bushes. Again, all knackered.
Brakes also needed attention, as did radiator and intercooler...all knackered.
Water pump and p-gasket.
Had 300k kms on it when I started. Most of the issues were due to a combination of poor maintenance and just being worn out.
I dont want to go bush and struggle with reliability so I opted to go through it like a dose of salts. Can't see the point in spending thousands on a tow from a remote area, seemed better to spend it on the defender to avoid the tow.
I always smile when guys get on here looking for cheap defenders....no such thing IMO.
If you know the vehicle and it's just getting a bit old then I'd definitely replace all cooling system hoses, the water pump and p-gasket and get the radiator rodded. Then check fuel lines (plastic and I found them rubbing through in spots), change all fluids and filters and pack one or two spare fuel filters.
Just give everything a good eyeball under the bonnet and replace anything split, cracked, weaping or leaking.
