Results 1 to 10 of 19
Thread: D3 Total blackout & power loss on highway
    Feb 2012
    Beaudesert Qld
    Hi all,
    Anyone got any ideas on this one? Driving on highway at night, 100kmh, suddenly with no warning, no dash lights or head lights, no throttle response & engine shutdown however indicator light worked as I endeavoured to move off the motorway. Pulled up, switched of ignition for few minutes, removed ign key, replaced it, switched on, "lights, camera, action" everything works fine including engine. Situation normal. Any ideas appreciated.
    Jul 2009
    You sure your not driving a VW? ...
    Sorry couldn't help it. ...
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D3 HSE TDV6 (Unfortunately Gone)
    D4 V8
    Land Rover special feature?
    Sounds scary. Had a few random faults etc appear at times which switching off, locking, unlocking and restarting fixes up, but nothing like that.
    Sep 2012
    Westlake ,brisbane
    OR A CITROEN C4 (LEMON) Our Citroen doese that but doesn't loose power but dealer wont beleave us when we tell them. DEAD DANGEROUS Do you know Citroen stands for citrus , Lemon.
    Dec 2009
    Ranelagh, Tasmania
    Quote Originally Posted by austeve01 View Post
    Hi all,
    I had a similar problem with mine, it only occurred on bumpy roads. It took a while to figure out as it was fairly intermittent and I'm not real smart.
    It turns out the weight of the other keys on my keyring was turning the ignition off when a large bump was felt. One solution was to put the keys in the other way around so the weight of the keys was trying to turn the ignition on.
    Another solution is to remove the other keys from the car key so it isn't flogging the ignition switch.
    The best solution was buying a D4 with no ignition switch.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Feb 2012
    Beaudesert Qld
    Quote Originally Posted by TerryO View Post
    Careful Terry .. my wife's got one of those and she reads this!
    Feb 2012
    Beaudesert Qld
    Quote Originally Posted by 1950landy View Post
    You're not wrong there .. dead dangerous.. and scary I can tell you.
    Feb 2012
    Beaudesert Qld
    Quote Originally Posted by Geedublya View Post
    Thanks for the info .. I'm hoping this is the solution to the problem. There is a fair weight of other appendages on the key ring. They're being removed! Personally I liked your last solution "buying a D4" .. sadly the wife's not interested yet
    Jul 2012
    Melbourne, Vic
    Did the same in my RRS, leaning down to scratch an itchy shin! Knocked the ignition off In a moment of panic I just flicked it back on again, still in drive, everything ok
    Oct 2011
    Sunshine Coast
    1950 Landy you live life on the edge A Landy AND a Citroen. Brave man
