Results 1 to 10 of 13
Thread: Coils anyone?
    Dec 2010
    South Scotland
    Coils anyone?
    This one appeared on my Facebook feed earlier, the idea has been done before, and has good potential as seen with various executions of it, this one just doesn't seem well thought out, and the back end just looks scarey.
    Western Victoria
    Rather odd spot to have the shocker tower.
    Up the occupants butts.
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    I'd like to see that get past a roadworthy and engineering in Victoria... I can weld better than that, and I wouldn't attempt my own chassis mods - neither should he. The rear radius arms look to be on the wrong angle? What a waste of a 101 chassis...
    Dec 2010
    South Scotland
    I've got a chassis prime for being reworked into a coiler, and a body to go on top.
    Now I just need to get hold of a scrap Disco to rob the rest of the mechanicals from, got ideas on how I might make it work with the disco pedal box and a decent PAS conversion.
    Potential to be a decent vehicle.
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by DasLandRoverMan View Post
    Sounds good, the big difference with that one compared to this one, is that you know what you are doing.
    Western Victoria
    I always thought the rear axles of that 6WD 101GS were coiled.
    Dec 2010
    South Scotland
    Could be right?
    There was a 6x6 camper that had leaves on the front and coils on the back. As far as I know it ended up in Spain with a new owner who pulled the extra axle and put it back on leaf springs.
    Last I was aware he was moaning because it didn't handle right and the Tdi in it didn't have enough power.
    Quite funny really.
    Dec 2009
    Williamstown, Barossa, SA
    Asking a Tdi to drag a 101 along is a lot but I'd have thought a 6x6 would be way too much!! Would have also thought that running the two second axles on an upturned leaf spring would give it the best ride as its still only sitting on one point either side whilst still giving loads of axle travel without each axle becoming light on the ground. Worked well with the old Merc Prime Movers.
    Western Victoria
    Didn't know what happened to that one.
    The one I was thinking of was thin one.
    Quote Originally Posted by Mick_Marsh View Post
    Still trying to get over this little sand dune
    [ame=http://www.youtube.com/watch?v=De0YHPmVdUI]6x6 Land Rover 101 cresting a dune - YouTube[/ame]
