Results 1 to 6 of 6
Thread: Salisbury Wheel Bearings
    YEPPOON QLD.
    Hi all, having trouble getting my RAVE cd to work on my Mac laptop. Can somebody please tell me the preload and any tricks to replace the rear wheel bearings on my '96 130. I've got new axles ,flanges ,seals etc and plan on doing the wheel bearings while I'm at it.
    Cheers James
    Feb 2005
    yeppoon eh.........i grew up in gracemere
    i assume you have a hub nut spanner? it makes the job far easier.....
    other might be able to explain it better than me.......i don't believe there is a set preload, while spinning the hub i run the nut run up until it takes out all the movement in the bearings.....no need to continue tightening. i repeat this a few times i.e. the weight of your arm on a long screwdriver that is through the hub nut spanner
    YEPPOON QLD.
    Thanks Weeds , Gracemere is a growing place, I pass through there every week. It even has a McDonalds now !!
    Feb 2005
    Quote Originally Posted by JamesB View Post
    well there you go.....its been a long time since i have driven though, cannot believe its big enough for a Macca's
    Geelong, VIC
    I've got one of the common tube spanners for doing the hub nuts.
    I usually use a screwdriver through the tube spanner to do it up quite tight while turning the hub by hand, then back off until its free, remove the screwdriver and tighten the tube spanner firmly with my hands (firm - not gorilla tight ).
    Not sure if that's anything like a recommended method but its worked well for me.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Feb 2012
    Parkdale, Melbourne
    I've got the tube spanner and put a screw driver through it as well.
    Luckily (and don't tell me boss) I have a copy of the D1 workshop manual saved at work for those curious moments.
    1.Fit hub adjusting nut. Tighten to 61 Nm.
    2.Back off adjusting nut 90°. Tighten to 4 Nm.
    This will give the required hub end float of 0,010mm
    One day I was bored and figured out that 4Nm was about the same as 2kgs on the end of my biggest screwdriver through the hub nut spanner. So hand tight on the tube spanner sounds about right for 4Nm.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
