Results 1 to 10 of 15
Thread: D3 Red Battery light on dash - why?
    Apr 2012
    Hi Disco experts...help needed once again.
    After a big day trip on Saturday, I started the Disco on Sunday only to notice the Battery shaped red light on the dash.
    So as I figured, I checked the batter and sure enough it was very low in charge and not seemingly holding charge.
    I tottled down to battery world and put a new battery in.
    Dash light went away.
    Then on the way home it came up, went away and then came up again with the new battery in.
    So to assume I would think it is the Alternator not sending enough charge, Any insight from Disco owners would be greatly appreciated
    Would it be water causing an issue, is this common?
    Last edited by rb30gtr; 15th July 2013 at 12:00 PM. Reason: I spell like a 2 year old..
    NSW SW Slopes
    Water itself shouldn't be a problem but mud would be. Hosing out the alternator (not while its running though) may overcome the problem if the brushes aren't badly worn from mud/dirt. Alternatively one or more diodes or the regulator may have been cooked.
    Apr 2012
    Great thanks,
    I'll get at it this afternoon with the pressure washer and see how it goes.
    It is not making any bearing or brush noises when running under load..yet
    Ben
    Jul 2010
    Same issue for me awhile ago and have posted about it.
    D3 issue only.
    Light comes on intermittently as alternator diodes fail then they short out and it costs you an Alternator and a Battery.
    Highly recommend you don't risk your battery and get the Alternator checked out A$AP.
    Apr 2012
    Quote Originally Posted by Peter View Post
    D3 issue only.
    Will do mate, thanks for the info.
    How much did a new alternator set you back if you don't mind me asking?
    Dec 2009
    Ranelagh, Tasmania
    $430 from Karcraft in Silverwater.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Apr 2012
    Quote Originally Posted by Geedublya View Post
    Excellent, thanks.
    Apr 2012
    I may need to request a quote for the none gold and diamond quoted version...
    Thanks- YLE500400 SUIT DIESEL 2.7TDV6 $579.85 OR YLE500410 SUIT 4.0LPETROL V6 $612.55
    + postage if required.
    our LANDROVER price file is attached
    Who did you get the $430 price from?
    Their price list is attached for reference.
    Attached Files Attached Files
    Dec 2012
    Adelaide, SA
    My alternator was around the $500 mark. Basically started her up after a long trip, burnt smell, whirring noise that changes with engine speed, battery light on.
    Checked charge with alternator ~11.5v.
    Was enough to start the car and drive the next day ~20km. Died soon after, started with numerous bongs, then Christmas tree lights, then trans started slamming into gears.
    If this happens to you and you expect to load the car onto a ramp, etc, try not to put it in PARK, as it will then lock you in park and you won't be going anywhere. I think garrycol had some advice to get it back out again which involved removing part of the centre console.
    Jul 2012
    North Shore
    If you're after a good Auto Electrician I recommend Henshaw Auto Electrical in Brookvale - Peter is very good, and does a lot of work for various dealers.
