Results 1 to 10 of 12
Thread: Gear Box Issues
    Shane and Lex Guest
    Gear Box Issues
    We have a 2012 Defender 90, took it out on the beach, heard a crunch in the gear box and lost drive! The gear box does now not engage front or rear difs. Has anyone had any similar issues?
    Jul 2011
    Yarrawonga, Vic
    do you understand that the high and low range has a neutral half way between,
    sounds like it wasn't put fully back into high after a jaunt on the beach and has popped into neutral , just pull the short stick back & see if that fixes it.
    Shane and Lex Guest
    Tried high, low and centre dif lock...gear box still not engaging...4 hr recovery by tractor...vehicle now on its way to Landrover (vehicle was in high range, second gear). Could not get any centre dif engagement just crunching!! $500 tractor recovery which Landrover is saying they will not pay for 4WD recovery...vehicle has less than 20000km.
    Jul 2011
    Yarrawonga, Vic
    Sounds expensive then, at least it wasn't one of those unfortunate enough to have the tide come in, hope its covered under warranty, keep us posted
    Jul 2009
    Lake Macquarie NSW
    What type of box is in these newer Fenders?
    Robbo
    Jul 2011
    Yarrawonga, Vic
    Quote Originally Posted by robbotd5 View Post
    Robbo
    It will be the Getrag MT-82 with an LT230 behind,
    The troublesome Mustang ones are made in China,
    not sure where the LR boxes are made.
    Shane and Lex Guest
    Landrover have informed me that the spline from the transfere box to gear box had the gear cogs had been stripped never seen before but I think that part is not made by landy anymore , but have been advised to fight to have the box replaced and just not repaired which sounds lick a job bigger than Ben her,landrover warranty will only replace what is broken,lets hope they get all the metal shavings out cheers Shane
    Safety Bay
    It's a 2012 model,it should have another 2 years warranty so all the costs are covered,they won't fix it,it will be a change out. Pat
    Shane and Lex Guest
    Pat have been told that they are replacing parts, I've asked to replace the box as my advise is the box will now have a shorter life due maybe bearing damage but landrover Albany are guaranteeing there workmanship fingers. Crossed , as soon as we get the car back our journey around aus can start
    Kingston, Tassie, OZ.
    We have had the same spline strip out on a 30,000km old puma over here.....so it DOES happen AND it was covered under warranty.
    JC
