Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: D1 v D3
    Jul 2009
    D1 v D3
    *updated with a few more pics added.
    The pics are of my old favourite 'Mountain Goat' D1 and the D3 that we are slowly building up to be an even more capable off roader than they are standard.
    Now most everyone knows that you can heavily mod a D1 to get lots of ground clearance and fit some pretty decent sized tyres.
    The pics show that these two Disco's have reasonably similar ground clearance and approach angles. The thing is the old Mountain Goat is no standard D1, it has a 2" body lift, 2" suspension lift and 33" BFG's fitted. Gloria has to just about stand on a box to get in it.
    Anyway the point is a D3/4 with some pretty inexpensive mods (LLAMS or GOE Rods and taller tyres) can come close to having similar off road height and suspension travel as a reasonably heavily modded D1. The D1 with its shorter wheelbase, better ramp over angle and just about no rear over hang though will still go places the D3 would struggle.
    Both vehicles are great and I enjoy both as much as the other. In realty both are quite different while being very similar.
    Note the big difference in height with the D3 at Off Road height plus LLAMS at full extension and at normal on road height.
    Thank you for checking out the pictures.
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D3 HSE TDV6 (Unfortunately Gone)
    D4 V8
    Moruya Heads/Sth. Coast, NSW
    Independent suspension has the major drawback that when the wheel travels up, the pivot point travels down, reducing ground clearance at that point.
    With a solid axle (D1) when the wheel travels up so does the whole vehicle, increasing ground clearance, D1's do rule, Regards Frank.
    Sydney, Australia
    Not quite that simple D3/4 air suspension models the system actually forces the other wheel to seek ground so has similar effect to solid axle. One reason why they are so good off road.
    Coilers are not as effective when cross axle'd.
    Apr 2010
    If it were a beauty contest there would be a clear winner. The D3 is a pretty ugly vehicle, I much prefer the look of the D1.
    Ever wondered where Landrover got the idea for the D1 styling from?
    Quote Originally Posted by CaverD3 View Post
    It cant be any simpler, "for every action there is an equal and opposite reaction", a simple law of physics, the pivot point at the bush where the bottom suspension arm connects to the crossmember will move down if the other (outer wheel end) moves up, has no choice, it's the law, Regards Frank.
    Dec 2009
    Ranelagh, Tasmania
    Quote Originally Posted by Tank View Post
    I'm a little confused by this statement, surely as a suspension system even a solid axle should move relative to the body and it has a pivot point.
    What you are describing is not a suspension system just a wheel mounted to a chassis.
    I understand that live axles have much more ability to drop and that the reaction on one wheel has an opposite reaction on the other. Definitely a solid axle has it's advantages in some off road situations however the huge unsprung weight and the inability to articulate wheels independently does mean that it is not as comfortable or as responsive.
    D1, D2, D3, D4 and Defender they are all just vehicles designed with different and evolving parameters. In my instance I need a vehicle to drive day to day in the city and then to escape on the occasional weekend either towing a 1.2 tonne camper or carting a tent and gear to out of the way places. The D3/D4 is the best compromise I could find for those needs.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    NSW SW Slopes
    That law is for energy, eg why a rocket engine propells the rocket, the recoil from a fired gun, not the mechanics of levers.
    NSW far north coast
    With an independent suspension when it's lifted from static ride height like that you do lose droop travel, but most solid axles that are lifted lose a respective amount of droop travel too, as (usually) only standard dampers are used, often the springs used have the same free length as stock, only the rate is increased, etc. etc. (not saying this is the case with Terry's, I have no idea what he's done to the D1)
    You have to do a bit of work with the RRC/D1/110 suspension to maximise it's performance and take advantage of potential travel increases, (dampers, damper mounts, bushes, etc.) otherwise they are both just a tyre and obstacle clearance increase.
    Totally wrong, Regards frank.
    Quote Originally Posted by Geedublya View Post
    If you loaded a large weight onto an independent suspensioned vehicle you could force the centre of the vehicle to touch the ground, the same weight on a live solid axle vehicle would not decrease the ground clearance under the diffs, Regards Frank.
