Thread: D1 radio antenna
    Mar 2011
    South Aust
    D1 radio antenna
    The radio in my D1 has very poor reception. Ive pulled out the head unit and checked the plug is full pushed in. It has the wire (antenna) around the drivers side rear window. Were they ever any good or should I just get a guard mounted antenna?
    Thanx
    St Helena,Melbourne
    4.28 MB
    I have never had any reception problems, are you in a rural area or small town ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2011
    South Aust
    Yep works fine in the burbs but really suffers in hills and rural areas, but just 50 k + from the towers it goes pretty quiet unless you on top a hill.
    Thanx
    Aug 2012
    Braidwood, NSW
    Hey mate,
    I have a guard mounted antenna, so I can't comment on the style you have. Though in previous vehicles I have had the rear window style antenna and it was usually only good for a little over 50k's or so.
    On that though, have you checked the grounding of the head unit? If the grounding of your radio is poor it can cause reception issues.
    Good luck,
    Chris
    Chris Phillips
    Offroader: 1996 Discovery 300TDI (The Green Donkey)
    Missus: 2010 Discovery 4 TDV6 (Fancy thing)
    Just 'cause: 1999 Discovery SE 3.9L V8 (Makes fun noises, sometimes...)
    Spares: 1998 Discovery 300TDI (Only vehicle actually in the garage..........)
    Run around:
    2001 Nissan Pulsar ST 1.8L (Soul crusher)
    Mar 2011
    South Aust
    Thanx Chris, ill check the ground and probably get a guard mounted one.
