Thread: Driver's window on Puma stuck open
    Well after 5 years of corrugations and so forth the driver's window wound down yesterday with a loud "crack" and disappeared into the door
    This was as we leeft home to go out bush for bbq. It wasn't going to wind up so we had a dusty 60km trip
    Anyway pulled it apart today thinking (from Disco 1 & 2 days) it would be the regulator rollers had busted. Wrong! All that had happened was one of the retaining bolts under the glass had dropped out and the other had loosened enough that the mechanism and glass detached. All back together again and unlike Land Rover I have put some mild locktite on all the threads as there was none. Now I just have to check the other 3 doors I guess
    Oct 2007
    Bamaga Qld - The Pointy Bit
    Hi All
    Hi mate, I guess its better than having to buy new parts and wait for them though
    I saw the headlines in the paper today - hope all is well
    Regards Mark
    That it is. Felt sure I was going to have a week with a faulty window.
    News came out of the blue as I've only just got back from leave a week back. Guess time will tell.
    Hey Derek its a known fault that the bolts in the door can come loose for the window..
    I have asked Ian some time ago to check ours because there is an annoying rattle which sounds like it is in the B pilar on ours been there for over a year and it wouldn't surprise me if that was it
    Apr 2007
    Looks like I'll have to check the bolts in my windows before we head up to the Central Arnhem Highway, seem like the corrugations rattle them loose
    Nov 2011
    You lucky yours lasted 5 years, i got to just under 2 before it happened on the drivers window one night. Pulled it apart and fixed it, then had the dealer fix it properly at the next service
    Is the known problem only with the drivers window or all of them, as it has only happened to the one so far.
    Richard
    I'm pretty sure that's it Lou. We had a rattle from B-piller or driver's side rear door for about the last year too and hadn't been able to track it down. Strangely it seems to have gone now
