27th July 2013, 07:45 PM
fuel gouge
for testing the pressure from the pump to the injectors, were i connect the pressure gauge?
what should be the reading on the gauge?
28th July 2013, 10:00 PM
Theres a valve on the fuel rail,test there, mine had 36 psi (you will get fuel come out as well)
Paul
29th July 2013, 06:20 PM
Here's a picture of one I made using a glycerin filled gauge. You can just see where it screws onto the fuel rail shraider valve.
