Results 1 to 9 of 9
Thread: Tyre pressures
    Sep 2009
    Adelaide
    Tyre pressures
    Hi all.
    Trying to work out my tyre pressures on my 3rd week of a 3 month trip. Have read about the 3 or 4 psi rule but am a little confused about towing and fully loaded.
    Have maxxis bighorn 762s in 245/75r16. Generally run 30 and 38 ish on the road unloaded. When I set off fully loaded towing my off road camper, pressures went up to 50-53 rear. I inflated to 46 psi and they still hit 55 after 20 mins of driving. Even when I put 49 psi cold, they still topped 56 hot. Not towing this day
    Do I need to inflate the rears to 52 psi? Seems an awful lot more than land rovers recommended 46 psi loaded.
    Maybe it's just the damned useful annoyance of having tyre monitors. I guess before those we all were blissfully unaware of the changes in pressure.
    Geelong, VIC
    Do the tyres feel just warm or are they hot? I know about the 4psi rule but usually rely more on temp when fully loaded or towing.
    If they feel hot then I put a bit more pressure in them and recheck after another few kms.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Feb 2011
    Brunswick, Victoria
    Just did a quick google and found the Maxxi's Bighorns you are running. They have a maximum inflation of 80psi and a max load rating of 1378kg.
    If you run these at placard pressures they'll be roughly 2psi under-inflated. To get closer to the right pressures you'd need to be running the fronts at 32psi, and the rears at 40psi or 48psi fully loaded. The placard inflation figures are based on a specific axle loadings - on the rear axle it's about 1450kg for the standard inflation and 1720kg for maximum pressure. If you have a higher axle loading than 1720kg you need to increase the pressure. For example with a 1800kg loading the rears would need to be inflated to 51psi. The weight on the tow hitch would need to be added to the rear axle loading.
    You've got plenty of "head room" to inflate the tyres so try bumping up the rears until you get close to the 4 psi rise. Make sure you check pressures about one hour after you do the cold tyre check. The ambient temperature needs to be roughly the same for each pressure check.
    Paul
    Dec 2012
    Perth, WA
    I've red a little about the 4 psi rule but I'm not convinced you can use it universally across all tyres and sizes.
    I posted is another thread about the differances in single make and model of tyre. The construction varies with sizes and that then affects tyre flex which will then affect heat and air expansion which is what is increasing the pressure.
    There are just to many variables. I frequently use a tread depth gauge every 10K km or so to see where thing are up to. If the centre is wearing more than the outer, I'll increase pressure. If the centre is wearing less than the outer, I'll reduce pressure.
    I thinks it's very dependant on your driving. If you live in Canberra and drive around 100 or so round abouts every week, you'll wear the outer of the tyres more and that area of the tyre will also be generating more heat and wearing the most.
    If you drive from Melbourne to Sydney all the time, you wont be doing many corners and the higher speed will create centrifical force and wear the center of the tyre more.
    Where the wear is, is where the heat is.
    Happy Days.
    Nov 2012
    penrith
    Can some one explain the 3-4 psi rule? I can't say I've ever heard it
    Dec 2012
    Perth, WA
    Quote Originally Posted by disco2_dan View Post
    Quick Google will find plenty mate.
    I think it started from some guy who wrote a Magazine articale.
    Basicly you check the pressure in your tyres when cold and drive for 20 minutes and check again. If the pressure is more than 4 psi than when they were cold then the were under inflated. If its less then 4 psi more then they were over inflated. Just change your cold starting pressure to suit. Well thats how I red it anyway.
    Happy Days
    Nov 2012
    penrith
    Can some one explain the 3-4 psi rule? I can't say I've ever heard it..
    Apr 2010
    South Melbourne
    Hi Paul,
    I think you should be more focussing on the cold tyre pressures and tyre contact length, and bulge look when warmed up as your guide. The loaded pressures you're running seem too high esp if you're on dirt.
    I found the Pink Roadhouse tyre pressure guide to be spot on for high speed dirt driving fully loaded. I gradually reduced my pressures to 24 front and 26 rear COLD with Maxxis LT 245 75 16. 753's. over a few months around oz. this gave the best ride and handling compromise. Fully loaded but not towing.
    Simon
    Road Stone Guest
    Hi
    I run 28 in the front and 30 in the rear, only because the roads are so bad here (Lae PNG) and in a vain effort that the tyres take some of the strain rather than the car rattle itself to bits!
    Cheers Jerry
