1st August 2013, 06:44 PM
Lost my speedo
Hey people i replace my clutch not long ago and since then iv lost my speedo. i did unplug it when removing the gear box i think maybe iv squashed the wire some where on top, it blew no12 fuse. Iv replace the speedo transducer so can rule that out.
But i was wondering if u can get to the top of the gear box with out taking it out again. i think if i could get right under the center console that would probably be right where the wire would run. And does the speedo wire go straight to the ecu.
1st August 2013, 07:35 PM
I have done it before too. Was simple as just loosening the 5-6 nuts and bolts of the transfer case and just pullin the wire out for me as it got stuck between the transmission and t-case.
Just run ur hand along the wire and make sure it's not caught.
Haven't done it since! Learned a lesson haha.
