Results 1 to 9 of 9
Thread: Wider track, Perentie or 101?
    Queensland
    Just a general question as I dont have specs of the 101.
    Any one know the track width and which is the wider?
    Didiman
    Jul 2011
    Yarrawonga, Vic
    dont know perentie dimensions but 101 as follows
    Dimensions
    Overall length, fully equipped
    4330 mm
    170.5 in
    Overall length, basic stripped
    4217 mm
    166 in
    Overall height, to top of windscreen
    2138 mm
    84 in
    Overall height, over hood (GS model)
    2283 mm
    90 in
    Overall height, Ambulance
    2500 mm
    98.5 in
    Wheelbase
    2565 mm
    101 in
    Track (distance between wheels), front
    1524 mm
    60 in
    Track (distance between wheels), rear
    1549 mm
    61 in
    Length of body (load bed)
    2491 mm
    98 in
    Width of body (load bed)
    1720 mm
    67.75 in
    Overall width, GS
    1842 mm
    72.5 in
    Overall width, Ambulance
    2350 mm
    92.5 in
    Turning circle
    11.3 m
    37 ft
    Minimum ground clearance under axles
    254 mm
    10 in
    Adelaide - Torrens Park
    1524 mm
    60 in
    1549 mm
    61 in
    The distance between the wheels isn't technically the track...
    Which Perenti are you interested in - the 4x4 or 6x6 - I think the 6x6 is wider in the track - body certainly is.
    101 front track is 60"
    Rear Track is 61"
    Not sure where this between the wheels comes from - not mentioned in the handbooks and repair manual. Infact the diagram in the manual shows track correctly measured centre of tread to centre of tread.
    Near Seven Hills, Sydney
    On a 4x4 110 I understand the track is 1500mm or 59", whilst on the 6x6 the track is 1700mm or 66.9"
    Seaforth NSW
    Track widths
    I understand this is the sequence
    Range Rover and 110 is 58.6" (1486mm),
    130 is 59.6" (1511mm)
    101 as above Front 60"(1524mm), Rear 61"(1549)
    Perentie 4x4 bit over 59" (1500mm); 6x6 66.8"(1700mm)
    Bob
    Last edited by bobslandies; 6th August 2013 at 02:51 PM. Reason: Mark beat me, drafted this this morning!
    WA
    The track width depends on the rim offset/backspacing.
    More important for the OP's purposes I assume is the WMS-WMS (Wheel Mounting Surface) measurement.
    IRC that the measurements are as follows:
    Series II/IIA/III : 55"
    RRC/D1/90/110/130 : 61"
    101FC : 65"
    Perentie 6x6 : ??? >66.8" by the sound of it.
    Jul 2011
    Yarrawonga, Vic
    Interesting question & interesting answers.
    As a comparison The Toyota LC200 track is wide 1640 front and 1650 rear.
    LC100 = 1620 /1615 and a 70 series cruiser is quite narrow at 1515f and 1420r
    The Iveco Daily 4x4 I'm considering buying has a track of 1670 F&R, so at least its not going to be far too wide for CSR etc.
    (esp if a perentie 6x6 has pushed its way thru first )
    Queensland
    Actually it came about from a discussion at a swap meet. This bloke said the 101 was wider than a Perentie. Of course me thinking of my 6x6 said no way. He was obviously referring to the 4x4 so I guess in a way we were both right.
