Results 1 to 3 of 3
Thread: What winch have you fitted in your ARB deluxe bullbar ?
    May 2013
    Perth, WA (Northern Suburbs)
    Hi folks,
    My query is now a combination of 2 of my previous questions about bullbars and winches.
    I'm interested to hear what winches people have fitted on the latest ARB Deluxe bullbar that DO NOT REQUIRE any modifications to either the body work of the car or fabrication to the bumper (excluding WARN winches)
    Apologies if this has been asked before. . . . . But I am new to the world of winching and would like to make the right choice of a winch that fits the bar . . . . Without spending a fortune.
    Fire away. . . . .
    Ian
    Apr 2010
    Connolly, WA
    Ian,
    If I didn't own a Warn I would be fitting an Avenger Mako TDS 9.5 without any hesitation.
    Look at local spec like the link below
    Avenger Mako TDS 9.5 (9500lbs) Winch - TORQ4x4
    It is also very much upgradeable if you should choose to do so as per the information on the Goodwinch site below (same winches, different branding)
    Goodwinch Winches & Parts, Electric Winches and Winch Bumpers, UK – Goodwinch.com
    Lou
    I just ordered a goodwinch direct. Wasn't interested in buying something then modifying it. Besides, someone else is covering the cost, About $2200-
    After mods the only thing of the original unit left is the motor end plate, the gearbox and tie bolts. New motor, drum, solenoids, waterproofed.
