Results 1 to 10 of 17
Thread: AVM 451 HUBS
    melbourne
    AVM 451 HUBS
    Can anybody tell me if AVM 451 freewheel hubs will fit my 1996 disco 1 with steel wheels. Any info will be greatly appreciated. Thanks - Russell
    Kiwiland
    They should, the 94+ defender fitment use the same hubs and axle. But why?
    Aug 2012
    Braidwood, NSW
    Quote Originally Posted by Dougal View Post
    Agreed, why? The drive shaft, the diff and the axles will all still be turning...... You might reduce some wear, but it would be a seriously small reduction. You're not going to get any steering back, the discos have a better turning circle than most 4WDs.
    I can only see it as just "spending" money. What are you trying to achieve. What is your end goal?
    Chris
    Chris Phillips
    Offroader: 1996 Discovery 300TDI (The Green Donkey)
    Missus: 2010 Discovery 4 TDV6 (Fancy thing)
    Just 'cause: 1999 Discovery SE 3.9L V8 (Makes fun noises, sometimes...)
    Spares: 1998 Discovery 300TDI (Only vehicle actually in the garage..........)
    Run around:
    2001 Nissan Pulsar ST 1.8L (Soul crusher)
    Won't you have to lock the centre diff if you fit free wheel hubs?
    melbourne
    amv 451 hubs
    I'm going to rebuild the transfer case using an Ashcroft part time 4wd kit, just concerned about the drive flange thickness of the AVM 451 hubs. My Disco is 1996 build I think it has thin drive flanges ? I'm trying to get conformation of their fitment to my vehicle.
    St Helena,Melbourne
    4.28 MB
    Thats my understanding otherwise there will be no drive at all.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Free Again Thanks Dan
    He quotes he is using a Ashcroft partime 4x4 kit
    East-South-East Girt-By-Sea
    1.20 MB
    And now we get back to the actual benefits of free-wheeling hubs versus the advertised benefits of free-wheeling hubs.
    Advertised benefits
    • Lower fuel consumption - has anyone found this? I haven't.
    • Lighter steering. The disco already has power steering.
    Disadvantages.
    • Rover diff not designed for weight of Disco when using single diff.
    • stationary drive train - adverse wear on prop shaft splines in single plain.
    • lack of lubrication to swivel bearings.
    • inability to engage 4WD in an emergency.
    • protruding FWH risk of damage when off road.
    • Unable to use LR alloys on vehicle with FWH.
    IMHO not worth the cost, you'll never recover it.
    Kiwiland
    Advertised benefits
    Disadvantages.
    Other disadvantages:
    Have to get out to engage 4wd (this is never in nice clean conditions).
    Anti-squat effect of front suspension is lost, result is nose lift acceleration.
    Cornering grip is diminished.
    Acceleration grip is diminished.
    Traction to move heavy objects (like trailers) on hard surfaces is lost.
    Tyre wear becomes very uneven.
    ABS on the front axle won't work.
    Fulltime 4wd is one of the best things about these landrovers. Why would you want to ruin it?
    Zackly!
