Thread: 300TDi service on Phillip Island
    May 2013
    Cowes
    Hi All
    New 300 TDi Discovery owner here. It is a 1997 model [build date 01/98]. I have some mechanical experience but not much money being semi-retired. The quote of $600-$700 for a minor service [engine oil and filter change] that I had today made me decide that I need to hone my mechanic skills or find a cheaper serice centre.
    I am on Philip Island in Victoria; any advice on reasonable mechanics in the area would be appreciated. Alternatively there may be self-serve facilities available that someone knows of. I have some of the skills and probably most of the tools but nowhere to work on the vehicle that is not six inches of mud.
    Also have a slow leak in one rear tyre and no F$%^&*&^ key for the spare wheel lock!
    best place for a service?
    see that slab of concrete its parked on in your driveway?
    yeah, right there.
    Feb 2005
    engine oil is pretty straight forward to do in your drive
    10L Oil
    1 x oil filter
    1 x 2L milk bottle
    19mm ring spanner? i think thats correct
    tip, cut the top off the milk container so that it is just taller the the filter, put it over the filter while you undo it, it not only catches the filter but also the oil sitting in the pump.....saves oil going everywhere
    don't forget to check the oil level again after you have run it up
    approx. $60
    May 2011
    Wyndham Vale. Vic.
    10L Oil
    1 x oil filter
    1 x 2L milk bottle
    approx. $60
    But only pour approx. 6 litres of oil into sump.
    Free Again Thanks Dan
    Quote Originally Posted by thelostboss View Post
    Hi All
    Im in Lang Lang im not a Mechanic but can do a lot more than some mechanics
    If you need a hand and a place with concrete Pm me
    May 2013
    Cowes
    yeah, right there.
    What is this "concrete" of which you speak? I have a driveway composed of sand, pine duff & possum poo - within 150 metres of Bass Strait!
    May 2013
    Cowes
    Quote Originally Posted by rangieman View Post
    Thank you for the offer. I will PM you when I have the appropriate filters and fluids organised. Are you averse to imported ales?
    Michael
    May 2013
    Cowes
    In preparation for this service I have read everything I can find on this site and others, but still have a couple of questions.
    I don't know what oil has been used in the past in this vehicle, can I just pick one to go on with or are there incompatible types?
    Same with coolant, what is in there seems to have no colour. How do I determine which to use in future?
    Any advice appreciated.
    Michael
    St Helena,Melbourne
    4.28 MB
    Any 15w40 diesel oil will be ok, coolant i think JC mentioned that use the same coolant that is spec'd for a commy V6 and you'll be right, if its clear now then i suspect its either really old or non existent.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Nulon long life is what ive used in my Tdi ,s Yes to the above Oil except make sure its Diesel oil
