Results 1 to 6 of 6
Thread: Ball Joint Failure?
    GJP Guest
    Ball Joint Failure?
    I came across a Prado yesterday with a collapsed LH front wheel and assembly, apparently no warning it just all fell away. The tilt tray operator said it was a collapsed ball joint and he had seen this occurrence about 30 times this year.
    This was new to me and I now wonder if this is a fail point with LandRover, maybe someone with experience with this matter could advise?
    MarknDeb Guest
    It is a potential failure point in any car, they should be inspected at every service for any movement
    mandurah
    Unlikely there would be a failure without some warning signs. Possibly had a front end knock and ignored it.....paid the penalty. Modern encapsulated balljoints should operate without any movement whatsover, unlike the older style balljoints, which generally have a manufacturer tolerance. ( and a grease nipple )
    D4 2.7litre
    Jul 2011
    Yarrawonga, Vic
    Exactly why I will never buy a 4x4 with independent suspension.
    ( I have also had an A-Frame ball joint fail (and let go) on my 90 without notice)
    Quote Originally Posted by ADMIRAL View Post
    thats what I would have thought too, before above happened to me, Also it beggars belief the number of Front props on D2's that let go without warning .
    Torres Straits
    Toyota tie rod ends (kinda like an IFS ball joint) have been falling apart regularly since Jesus played for Nazareth under 13s...
    A TRE is easy to fix with some fencing wire though so I guess it doesnt really count as a failure!
    Wasnt there some photos on here of a playdo or somesuch having a lie down in a sand pit with busted ball joints and ejected driveshaft just a few months ago????
    S
    Oct 2006
    canberra
    Yup upper and lower joints fail on late model tojos all the time and the playdos had a problem with the rear wheel bearings extracting them selves too if memory serves me right
