Results 1 to 9 of 9
Thread: Suspension help
    DiscoDisco Guest
    Suspension help
    Hey there.
    I'm new here and after some advice, so thought i'd ask some people that would know.
    I'd like to know whats needed to get my Rig more capable.
    Lets just say i have a 2 door auto and id like to run either 33's or 35's.
    I don't to just lift it and make them fit, i'd like to lift it and have the suspension really working with the most wheel travel possible.
    I'd like to do it right the 1st time rather than have to redo things.
    Where's the best place to start looking for parts to do this and whats some things to keep in mind while im at it?
    Thanks in advance.
    Aug 2012
    Hey they, I've just done a 2inch lift on my D2 and forum help has been invaluable.
    I'd say have a good search through and read the good oil and then ask specific questions about what you want to do/achieve otherwise you'll get lost amongst conflicting advice.
    The other thing to be aware of is if you want your car to be legal you need to keep within a certain height change - take a look at the ADRs and advice for your state!
    Good luck!
    St Helena,Melbourne
    4.28 MB
    Go thru the post up your disco and mods top of this section and read what other members have done, this will give you a good idea of what is possible and what it will look like.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    DiscoDisco Guest
    Its going to be used as a weekend warrior/weekend camper.
    I'm not to concerned if the vehicle is goimg to sit outside what others consider road worthy. I won't be cutting corners with what i fit to it.
    Have been looking through other posts, doesn't seem to be much info on where the parts come from though. Any help with that would be great.
    May 2006
    Woolgoolga
    Body lift
    Superflex arms
    Suspension stuff flexy coils
    Bilstein 7100. 12 inch shocks, or gq/80 series shocks
    After market axles
    Ashcroft lockers
    Heavy duty track rod/drag link
    Flares
    35's
    Ya done
    99.87 MB
    Quote Originally Posted by Vern View Post
    Vern, do you know what the rates are on these?
    Slunnie
    May 2006
    Woolgoolga
    No, was going to give them a call, from there website they say they do all sorts of rates, they just need info as to what you are running on the car. Think they are more like keep a progressive rate coil??
    Aug 2011
    Melb
    Howdy DiscoDisco!!! Welcome pal.
    if you need to search for items or threads use the search bar on the bottom left of the page!! only took me 14months to find that out!!! best tip you will get
    Aug 2012
    Quote Originally Posted by Vanderz View Post
    Put 'site:aulro.com' (without quotes) in your google searches to restrict just to the forums.
