 Originally Posted by
Grappler
				My Puma 2.2 130 runs at 94-95 according to the Ultragauge.
The gauge on the dash is mid scale indicating normal. The UG derives the value from the vehicle sensor so the accuracy will depend on the quality of the sensor used. According to WS manual, the thermostat starts to open at 82 and is fully open at 96 If the UG value is correct it doesn't give much scope for working hard on a hot day with AC on etc
Ive also plugged the UG to the wife's RRS and it appears to runs about 8 deg cooler at 87-88 in the same conditions.
Follow the fuel calibration procedure to get your fuel alarms more realistic.
The Puma 2.2 fuel cal factor was 0.37 from memory. (away at present)
