                                                21st August 2013, 07:06 PM
			Under seat plastic panel
					What's the best way to remove the plastic panel under the electric front seats? I notice a bracket under the passenger seat that may be ideal to mount a UHF, and there appears to be significant metal bits behind the driver's side, perhaps enough to mount a fire extinguisher.
 I tried gentle pressure, then a bit more, but they didn't budge. Thought I'd check before I break something.
                                                21st August 2013, 07:13 PM
					Held on by only 4 Iron Man clips, these suckers are a pain to remove.
 If you lift the seat to its highest point you can see the 4 clips holding it to the metal plate.
 This gives you an idea of where they are & how it comes away.
 Sent from my iPad using Forum Runner
                                                22nd August 2013, 07:53 AM
					Easier to fit from the rear probably?
