Thread: D3 vin number with rear aircon
    mattg Guest
    Hi guys
    I am wondering if someone could PM me their vin number If you have a d3 with rear aircon in a 7 seater. I am looking at retro fitting a 2nd and 3rd row aircon system into a d2. I believe the d3 system runs off a separate 12v compressor heat exchange unit and may be easier to use one of then instead of trying to run pressure lines from the motor all the way to the back.
    Any way the request for the vin number is to make it easier to loot up the parts on microcat.
    Help appreciated.
    Cheers Matt
    NSW SW Slopes
    The D3 rear air uses pressure lines to a rear evaporator.
    Bangor, NSW
    Hi Matt - here is the VIN for my previous D3: SALLAAA137A414021.
    It was an MY07 SE TDV6 with 7 leather seats and rear a/c.
    Rob
    Oct 2008
    Cloncurry NWQ
    And just to double up SALLAAA139A which is an 09 D3 with rear A/C & rear entertainment TDV6.
    Jonesfam
    mattg Guest
    Thanks guys door closed on that idea. I am going to stick with the d2 gear.
    Matt
