Thread: tips for removing rear prop shaft internal seal
    Aug 2011
    Melb
    I need to replace the rubber coupling tonight and looking at the workshop manual looks like i need a slide hammer with an internal clamp to remove the metal/rubber bush that sits inside the rear prop shaft. Anyone have a way that doesn't require this tool?
    Mar 2011
    South Aust
    I got mine out with a hack saw blade. Very carefully cut out from the center until you can collapse the old bush and get it out.
    Aug 2011
    Melb
    Wow that sounds time consuming!!!
    May 2012
    Gloucester,NSW
    I found a hammer and cold chisel worked well...
    May 2010
    brisbane
    Arrow rear coupling
    I replaced mine with a new 4 bolt kit.Get rid of the donut.I had to grind mine off very carefully as the heat required to pull the spigot out was a pain.No more worries about splitting the rubber in the field as its the same as a defender one now
    Aug 2011
    Melb
    that looks like a far better option. pity ive already bought everything i need to replace. what did the conversion set you back?
    Avoca Beach
    On a D2 anyway , you don't have to remove the spigot guide thingo.
    Just undo 6 bolts and do em up.
    You have to remove the spigot to do the oil seal in the diff.
    Regards Philip A
    Aug 2011
    Melb
    i dont even know if the seal needs replacing i just received one in the kit with the donut. so i assume you usually replace them at the same time? nothings leaking...for a change.
    Mar 2011
    South Aust
    Quote Originally Posted by Vanderz View Post
    Yep bout 2 or 3 minutes.
    May 2008
    Lismore, NSW
    If it is steel you could run a weld around the inside of the spigot.
    This should shrink it enough for it to slide out.
    Warren
    Currently Landroverless - Still interested
    Formerly: 2003 D2a Update TD5 Auto. Platinum edition. ARB Bar, 36" LED light bar, cargo barrier, dual batteries.
