Results 1 to 10 of 32
Thread: Ashcroft hd cvs & axles or Allisport intercooler?
    May 2010
    Gisborne
    Question Ashcroft hd cvs & axles or Allisport intercooler?
    Hi all
    I've saved my pennies and I can buy either the Ashcroft hd cvs and axles or the Allisport intercooler.
    Question?
    I don't know which I should get first.
    I'm edging towards the intercooler as it is beneficial for the engine.
    Love to be able to get both but I would get shot.
    What do you reckon?
    I'm running 33s atm but do want to build the car up to run 35s.
    Mick
    redrovertdi Guest
    I have the intercooler, if yours is a 200/300tdi you will also need to budget for the injection pump tune or there will be very little difference if any, how ever once tuned to suit it is well worth it
    May 2010
    Gisborne
    Mine is a td5 with remapped ecu.
    Jul 2011
    Yarrawonga, Vic
    Mick,
    for the type of 4wheeling you do. I'd go the axles and cv's
    do you have an EGT, if you going over 700 too easily or doing a lot of highway towing then, yes the intercooler
    Jun 2008
    Drouin East, Vic
    I've just put Ashcroft HD axles, CVs, flanges & diff through my 130 and have not even contemplated an intercooler so I guess that's pretty representative of my opinion. I often go out alone in demanding terrain and I don't like getting stranded.
    Feb 2012
    Mundaring, WA
    G'day Noogie,
    I'm 100% with Going Bush and POD.
    If your going 35s it's no use sitting in the bush for hours with a brand new intercooler waiting for a tow because your CV's are buggered.
    Hope this helps, Good luck!
    May 2010
    Gisborne
    Mick,
    Hi Don
    I've gotta get an egt gauge.
    I don't tow as much as I used to and only do the occasional long hwy trip. I'm not clocking up big ks these days either.
    Gotta say that I do get little paranoid about breaking something with the front locker on.
    Yeah the cvs/axles do make more sense.
    I don't really need the extra performance just the cooller egts.
    Mick
    Geelong, VIC
    Once you've got a gauge, EGT's are easily controlled with your right foot, and are never an issue offroad in my experience (except maybe in sand).
    Go with the axles/CV's
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Central Coast NSW
    Go the Ashcroft gear.
    Had my CV's, drive flanges and half shafts in for 4 years. Never had a problem and they make you feel much more confident when off roading.
    I put the Allisport inter cooler in after the drive line up grade.
    Just put Ashcroft's new HDP38 air locker in
    ashcroft definitely make the best cvs to date, but have you priced Hi-Tough Engineering for axles and drive flanges. They are on the Gold Coast and locally made.
