What Mac do you have
What is capacity of HD
How much Ram
What processor?
Well, I waited for the NBN to be connected before I updated our iMac operating system. The download went fast and smooth and the update started OK until...
The installer program identified my 'Macintosh HD' and then said that Mountain Lion could not be installed on the hard drive. I do not have any other hard drives, what is going on?
I have 668 Gb of hard drive memory my system requirements are OK for Mountain Lion, any suggestions?
How much Ram
What processor?
If you are sure your mac meets the minimum system requirements and you can back up all your data and have the ability to reinstall your apps then you could do a disk erase and install as per this guide:
How to Clean Install Mac OS X Mountain Lion
I have done this on 2 macs and it works well.
Simon
I have a 2009 iMac, 2.66 GHz Intel Core 2 Duo, with 8 GB 1067 MHz DDR3 and 668 GB left on the hard drive.
None of the above means anything to me, and the words disk erase sound a little permanent.....
If nothing else works I may be tempted...
You need at least the following
Lion System Requirements
1. Mac computer with an Intel Core 2 Duo, Core i3, Core i5, Core i7,
or Xeon processor
2. 2GB of memory
3. OS X v10.6.6 or later (v10.6.8 recommended)
4. 7GB of available space
5. Some features require an Apple ID; terms apply.
Upgrading to Mountain Lion
To upgrade to Mountain Lion you must have Snow Leopard 10.6.8 or Lion installed. Purchase and download Mountain Lion from the App Store. Sign in using your Apple ID. Mountain Lion is $19.99 plus tax. The file is quite large, over 4 GBs, so allow some time to download. It would be preferable to use Ethernet because it is nearly four times faster than wireless.
OS X Mountain Lion - System Requirements
Macs that can be upgraded to OS X Mountain Lion
1. iMac (Mid 2007 or newer) - Model Identifier 7,1 or later
Check you meet the above requirements, check which system is currently installed. you should be ok with the hardware you have mentioned.
Without stating the obvious, I assume you have paid for mountain lion via the Apple store. You can download copies but they won't load until you actually pay for them.
Let us know how you go.
Take it to your local mac store and ask them - see what it costs; that's the one thing I've found great - their backup and customer service. Mind you, we pay for it up front and I've always done it under warranty.
Mind you, I took mine in for some other minor problems and got snow leopard to mountain lion for free but then I've lost the ability to upgrade iphoto and imovie - now they (app store) want me to pay for it, so I'll go back and kick and scream and they'll likely give it to me for free.
Well I'm back on line.
Mountain Lion would not install because 4 years ago I made a mistake and backed up to the internal hard drive. The operating system of the time had a fault and even though I rectified the mistake and spent the next 4 yrs backing up to my external hard drive it still registered my internal drive as a back up.
So erase and internet install required. This got me Lion back and fixed the issue so Mountain Lion installed.
Then auto migrate did not detect my latest back-up, it only found one from 2010. So manual migration required. All done and everything working fine.
Not that I can take any credit for it, it was all Apple support. Free, over the phone, 40 min a night for 3 nights (had to wait overnight for stuff to down load/back-up). They even phoned me back each night at a pre-arranged time. Not bad for a $20 purchase.![]()
What was the $20 purchase? A support plan?
Thanks - that reminds me I need to get onto them to sort out my imovie and iphoto that won't upgrade. It seems it was included in Snow leopard but not in the upgrade to mountain lion so I've lost the ability to upgrade. I get the message to log into the account I used to purchase it in the first place. Anyway, good new eh; you're up and running![]()
