Results 1 to 10 of 23
Thread: Sneaky pulley noise..grrrr!
    Oct 2007
    Williamstown, Victoria
    Last week I started to notice a slight tapping/squeal noise, which definately sounds pulley related.
    It happens under load and comes and goes a bit.
    I had never changed my serpentine belt, so for good measure I put a new one on today.
    As soon as I drove off the noise is still there.
    While the belt was off, I checked all the pulleys for any rough rotation, they all felt perfect.
    This is a bit of a hard one to diagnose, as it will not make the noise while idling, only while the car is actually in motion and under load.
    Now like most of you, I like to keep my P38 in good order, and noises of any type need to be investigated, to avoid something chucking a wobbly while driving.
    I'm not getting any warning lights on the dash, the car is driving perfectly otherwise.
    I'm thinking belt tensioner or pulley maybe?
    I'm hoping it's not a bearing giving way somewhere...
    Has anyone else had this happen?
    What would be the most likely culprit?
    2001 4.6 Thor HSE
    Cheers, Pete.
    Coogee, South of Fremantle, WA
    I had a pulley / belt noise most noticeable on tickover. It drove me crazy trying to sort it. I was convinced it was the air con compressor clutch bearing as I could stop and start the noise with the aircon kicking in. I changed the clutch bearing and still had the noise. The alternator is not very old so discounted that. I then changed the pulley under the power steering, still there. Then the tensioner Pulley, still there, Finally I got to the Idler pulley directly below the alternator, Result noise gone.
    The pulley in question is Plastic. The surface had worn down until only a very thin layer was left, I think I put a post up at the time with a warning.
    The new pulley is a nice chunk of steel.
    I just found this Picture of a failed pulley, mine was still intact but as you can see the surface wears away and its not clear until BANG. Maybe not your issue but I would look there anyway.
    Have a read, if yours proves the same maybe post again with a general warning........
    Thor engine idler pulley ( Under Alternator)
    May 2010
    Mindarie, Western Australia
    I like the look of the bogan battery cover
    Gary
    Quote Originally Posted by mtb_gary View Post
    Gary
    Can I please clear this up before it gets out of hand and rumers start to spread, Thats not my car, Not my battery cover, I have never owned a Lumberjack shirt and never will.
    ( No offence to lumberjack shirt fans)
    Oct 2007
    Thanks for sharing that Wayneg, great photo too!
    I might get under there again tomorrow, pull the belt back off and check that pulley.
    I know sometimes these things become a process of elimination, but that is a good start.
    Will let you know how I go.
    Quote Originally Posted by PeterH View Post
    Just an add, I looked at the pulley at the start and it seemed fine, at least the bearing was not noisy. Now I know the surface should be flat right across the belt contact surface. If you have ridges at the edges thats the sign of wear, I presume the plastic becomes so thin it starts to flex
    Oct 2007
    OK, the noise is getting a bit worse today, and still only does it during driving.
    When at idle there is no unusual sound at all, which is a bit frustrating to say the least!
    I let the tension off the belt, checked all the pulleys and every one turned freely without any noise.
    The idler pulleys are both metal ones and I could not detect any problems with those.
    I did notice a 1mm movement when I pulled on the steering pump pulley, and in and out movement rather than a side to side movement. The pulley spins freely though, with no noise nor roughness at all.
    There was also a very slight movement of the fan via the viscous coupling, but it seems to be working fine.
    The sound has develpoed into what sounds like a chirping belt, sometimes catching, like a metallic clunk.
    I'm wondering if I'm on the right track, maybe it's something else, but so hard to tell as it only happens while driving.
    Anything I'm missing here?
    Thanks, Pete.
    PM sent
    If you turn the aircon on, when the compressor is running you will put additional load on the belt, does that force the noise to start? Also recall someone had the power steering pump pulley work loose
    Power steering pump pulley bolt thor
    Oct 2007
    I just got my lovely lady to drive the Rangie for me, while I listened from outside, and could hear the clunks quite loudly...I'm thinking it may be a broken axle!
    I had not heard it from outside the vehicle before, but had noticed a new clunk when taking off in forward or reverse.
    I'll jack the front up tomorrow and see if I can spin the wheels by hand...that would explain why all the pulleys seem fine!
