Results 1 to 3 of 3
Thread: Buggered compressor..advice?
    Oct 2011
    Burra NSW
    Hey guys, finally diagnosed my air suspension inactive fault as tank pressure static when filling, should I put a new one in, or rebuild the old one? It's a 2004 with 120k on it...I have been told by two different specialists that the updated compressors( not the hitachi ones) are a much better unit, but require the compressor ecu to be calibrated with the vehicle..the hitachi compressors are still available though but not as good.. Thanks in advance.
    Aug 2010
    Sunbury, VIC
    I would get a rebuild kit and put that in. I posted a part number somewhere for one. Quite cheap and easy to do. It's just the rings that fail, so bung on a new set and you will be fine for quite some time to come.
    Dec 2009
    Tyrendarra Vic (South West Vic )
