Results 1 to 6 of 6
Thread: D1 200tdi Air con question
    Hi All
    I have a 92 Disco 1 200 Tdi
    The air con does not work , but before I get raped by a air con company. Need to ask some questions and check the simple things first
    Does the compressor make a noise when it starts ( IE you turn on the air con in car) as mine does not, if this is not right what do you suggest may be the cause
    Also when off roading and bouncing the car about a bit on rocks the air con worked for a bit , not really cold be colder than it has been. Then stopped and back to how it was.
    Any ideas or suggestions welcome
    Ali
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Barmera .SA.
    Check under the bonnet to make sure the magnetic clutch is actually working properly.
    Engine running, switch A\C on and watch to ensure the compressor is actually being turned.
    Next problem would most likely be the usual leaking seals at the compressor crankshaft, that one is a replace and regas job, sorry.
    Other than that, there's not a lot that can stop them from working, the rest of the system is just heat exchangers really. No moving parts in them to wear and break down.
    Quote Originally Posted by shorty943 View Post
    Ok really stupid question
    How do you know if the compressor is being turned , the belt on the front turns seems to turn and it seems to show no different signs if the AC is on or off.
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    if it is the same as the 300tdi then a solenoid pulls the clutch in on the compressor pulley assembly
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    feel free to drop me a PM if brisbane puts you within reasonable range of the switch....
    the clutch is in the middle of the compressor puuley when you power up the compressor by turning on the AC it engages the outer driven half of the pully to the crank of the compressor.
    the first test is to apply 12v straight to the compressor and listen for it to clunk. if it does this then start the engine and run high idle for about 20 seconds. with the fans on low. while this is happening watch the glass on the reciever drier, if you see bubbles and snot being blown through it your system has a leak and has just lost gas.
    you might get lucky and it might just be a dodgy connection or fuse but I suspect that it will be out of gas and the low pressure cut out is kicking in.
    Thanks for your help
    Will check
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
