Results 1 to 10 of 24
Thread: EGT Gauge sensor location
    May 2010
    Gisborne
    Question EGT Gauge sensor location
    Hi all
    I got my EGT gauge from the USA yesterday, and as previously mentioned on my other post, it was decided that the best location would be where all manifold pipes merge on the manifold.
    I have attached a couple of pics in order to establish the best spot.
    I'm thinking I'll mount it on the small raised circular spot just after where the pipes meet.
    What do you think?
    Apr 2010
    That'll do it. Will it fowl the turbo heat shield one installed? or are you going to throw that away? Mine is in the same position just angled back towards the bulkhead as my sensor is quite long. BTW it is the tip of the sensor that reads the temp so make sure the tip is in the center of the gas stream no touching the manifold and giving you the manifold temp reading.
    Ian.
    May 2010
    Gisborne
    Thanks for that.
    I can't see why I couldn't modify the heat shield so I don't have to lose it.
    What gauge welding rod did you use for the manifold adaptor plug?
    Apr 2010
    I guess you could easily snip the shield, personally I've done away with mine.
    Not sure what you mean with the welding rod. My sensor is mounted in a brass compression fitting tapped into the manifold, it has a tapered thread so is pretty much self sealing. I know next to nowt about welding. Interested to know how you intend to fit the probe though.
    Ian.
    May 2010
    Gisborne
    I'll have a go at explaining it.
    An 8mm hole is drilled into the mounting place.
    Over this home you weld a special steel sleeve which the sensor probe feeds thru into the manifold. The probe is then fixed by a threaded coupling to the sleeve.
    I hope that makes sense.
    Why not just drill and tap a hole in the manifold and use a compression fitting as Mools suggests, that way no need to weld
    May 2010
    Gisborne
    What's a compression fitting?
    Any photos?
    Kiwiland
    Quote Originally Posted by noogie View Post
    Any photos?
    Like this, there are several different styles but you need steel or stainless steel. Brass will soften and keep loosening at exhaust temps.
    Geelong, VIC
    There's some piccy's and instructions at the bottom of this page too:
    EGT Probe, Exposed Tip [TC-KEGT] - $36.50 : auberins.com, Temperature control solutions for home and industry
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Jul 2009
    Lake Macquarie NSW
    Hey mate, just dump the turbo heat shield. Mine has been off for about 20000ks with no Ill effect. Along with the engine accoustic cover. A lot of that was towing our camper (23ft van!). Agreed about the ideal position for the sensor.
    Robbo
