Results 1 to 10 of 11
Thread: D2 front propshaft to Defender?
    Jun 2008
    Drouin East, Vic
    I know that the length is different, also that the flange bolt-pattern is different, but is there any other reason why a D2 double-cardan front propshaft would not be a suitable starting point from which to fab a front propshaft for my Puma 130? I'd like to give it a bit of a lift at some point and would like to have the propshaft sorted first. Can the front yoke be interchanged to overcome the bolt-pattern issue?
    99.87 MB
    I would use larger joints, 1310.
    Slunnie
    Feb 2009
    Mt Barker, SA
    you just have to change the output flange on the trans case to a D2 one and then get the shaft lengthened and balanced HOWEVER I did this with my Puma with a 2 inch lift and wore out the DC joint twice in <10,000k and at the end of that the diff end uni was buggered too. You can have it re-built with a Hardy Spicer heavy duty D2 DC joint which should improve it or you can get a Tom Woods (or other DC shaft) from overseas - if you do a search there is plenty on this in the forum. I ended up getting Hardy's to make me a custom shaft.
    Do yourself a favour and get a Woods shaft
    Wayne
    ​VK2VRC
    LowRange 116.76:1
    Jun 2008
    Drouin East, Vic
    Wow I have no desire to introduce components to my vehicle that are going to wear out every few thousand K's, life is busy enough as it is. Would greasable unis in a D2 shaft solve this?
    I got a quote on a DC joint from Spicer's and they offered me a 'special price' of $1800 for the joint alone. I declined.
    I did search on here, didn't come up with anything specific about the D2 shaft to defender hence the original question.
    Am I right in thinking that the shaft from Tom Woods comes in at around $750?? That's why I'm looking at more budget options.
    Geelong, VIC
    I don't have any personal knowledge on the Pumas, but isn't the D2 shaft a problem even on a D2?
    I could be missing something, but by the time you buy an new D2 shaft and have it modified to suit you'd be up around the price of a custom made Woods shaft anyway, and have a much lesser product in your hands.
    I'm not sure how that would make the D2 shaft a more budget option.
    Edit: IIRC the Woods DC shaft I had made for the County was a bit over $500 a couple of years back when the dollar was a bit better than it is now.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Feb 2009
    Mt Barker, SA
    Quote Originally Posted by steveG View Post
    Steve
    yep, Steve is right - thats what I was getting at in my round about way. Just a D2 shaft will set you back around $580 new, then the mods. The quote I got from Spicers for a custom D2 shaft with their HD DC joint and stronger 1310 joints was $924. I think your price of $1800 for the joint only would be for their CVX-30 Cornay joint ehich is a whole different kettle of fish - see pic
    Heres a link for the Woods shaft if you want to investigate. Tom Wood's Custom Drive Shafts - Tom Woods Custom Drive Shafts Custom Driveshafts Specialist
    I dont really think there are any reliable budget options for a front Puma shaft - better to do it properly or maybe forget the lift?
    n plus one Guest
    Get a woods and be done with it...
    NSW far north coast
    There will more than likely be a brand spanking new Woods shaft for sale in the markets section soon specifically made for a Defender as a courtesy to Tom Wood, complete with a Defender/D1/RRC output flange.
    It's being offered to someone prior to listing, if they don't want it, up it goes.
    Tom is out of pocket ATM and I want to help him get his money back.
    Stay tuned.
    Jun 2008
    Drouin East, Vic
    Quote Originally Posted by rick130 View Post
    Stay tuned.
    I'll definitely be interested Rick, will keep my eyes open.
