Results 1 to 10 of 12
Thread: How does one..
    Back down the hill.
    How does one..
    ...self administer eye drops?
    Sep 2012
    Adelaide Hills
    before laser eye surgery i used to put contacts every day.
    on your left eye, open eyelids open with left hand.
    use right hand to hold bottle between thumb and forefinger.
    tilt head back, hold bottle about 2cm away from eye, squeeze drops in.
    for the right eye, hold eyelids with right hand.
    Apr 2012
    Orange, NSW
    Eye don't know...
    Make sure you take pics, that'll be a sight for sore eyes.....
    Okay, I'm done....
    What Eevo said.
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
    Sep 2012
    Adelaide Hills
    Quote Originally Posted by Disco Muppet View Post
    Eye don't know...
    Okay, I'm done....
    What Eevo said.
    i see what you did there
    Gosnells
    ... with a steady hand...and much bravery.
    "It is by will alone I set my hand in motion....."
    - apologies to Frank Herbert.
    Back down the hill.
    Thanks guys; I tried your method Eevo, half a bottle down the cheek and temple later, I got two drops in the eye. Superquag speaks from experience by the sound of his observation.
    Apr 2012
    Orange, NSW
    It takes a while to get used to it.
    I found it much easier lying down, because when you look up you start to lose your balance.
    It takes a while but you do get used to it.
    An odd sensation.
    Hay Point
    Down a couple of decent bundys first Ian, then your reactions aren't as fast and you can get it in before you blink. You still coming this way?
    Cheers......Brian
    1985 110 V8 County
    Ocean Reef WA
    I've done it a few times by just looking in the mirror and holding each eye open as required.
    I'm now doing the same thing for the Cook who is what the eye specialist call a "blinker"......that ain't what I call her and it makes it hard when the eye lid keeps fluttering.
    AlanH.
    Feb 2012
    Cleveland
    I find the best for me is to hold open the eye lid with the same side hand, I then tend to drop the drops into the corner of the eye closest to my nose with my head tilted slightly away from centre, seems to work pretty good and you can steady your hand on your nose too. Never had a problem since using this technique, my Doc told me about it and works a treat
