yes it can, the diesel can leak down through the housing joint and gets fanned around in the fly wheel housing.
the quick check for this is to pull the crank angle sensor and have a look at it, if its got a sheen on it and has picked up gunk then you are likely to have clutch contamination.
 . using an engine bay support
