Thread: Microsoft Word Table of Figures & APA 6th
    Mar 2010
    Queensland
    12.97 MB
    Hello All I.T, people,
    I have to form a Table of Figures - well actually a table of tables in a document and due to the format of APA 6th I am only picking up a the table number and the page location.
    APA 6th insists that the Table style is ...
    Table 1.
    How useless is this - you have to drop a line to read the label for the table.
    While for figures it is really simple and the TOC works because it is all on one line ...
    Figure 1. Much more user friendly.
    Is there any way that I can expand TOC search to include the second line for Tables when it does its automatic list updates?
    Kind Regards
    Lionel
    Nov 2010
    Adelaide
    I'm not overly clear on what you're asking, but the table of contents is populated using outline levels.
    You can 'tell' the TOC what levels to include, typically restricted to level 1 or 2.
    You can set the outline level for a style from the paragraph properties dialog. If the text isn't created automatically you could create a new style for the captions and apply the heading level.
    HTH
    Bracken Ridge, Qld
    I'm not even sure this thread is in English ! Sounds like spam to me...
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Mar 2010
    Queensland
    12.97 MB
    Quote Originally Posted by theresanothersteve View Post
    HTH
    G'day TheresanotherSteve,
    Does this mean that I can make Word pick up two lines of text instead of one to incorporate with the table of tables? I have no problems with the Table of Contents (Figures) because in APA 6th the label on a figure is all on a single line.
    At the moment with APA 6th and there being two lines for each label/caption and Word only picking up the top line it makes for a 50% accurate Table of Contents (Tables).
    As a reminder the format for tables in APA 6th is...
    Table 1.
    This Table is About Blah - blah - blah
    Kind Regards
    Lionel
    Mar 2010
    Queensland
    12.97 MB
    HTH
    Does this mean that I can make Word pick up two lines of text instead of one to incorporate with the table of tables? I have no problems with the List of Figures (Figures) because in APA 6th the label on a figure is all on a single line.
    At the moment with APA 6th and there being two lines for each label/caption and Word only picking up the top line it makes for a 50% accurate List of Figures (Tables).
    Table 1.
    The list of Figures under the main taskbar tab of References does not seem to let me change picking up from one line of information to the two lines necessary to grab the full Table Caption/Label
    Kind Regards
    Lionel
    Mar 2010
    Queensland
    12.97 MB
    Sorry for the double posting
    Hello All,
    Seems like when I revisited the message to attach some screen grabs of the area in question I have actually posted the same message twice. Now I am taking up more space with the apology
    Oh and at the end of my first post I should not have written in the last line Table of Contents as I should have written like I had done earlier throughout the message "Table of Figures" or in my case "Table of Tables"
    Kind Regards
    Lionel
    Mar 2010
    Queensland
    12.97 MB
    Examples
    Hello All,
    The first attachment shows what Word is producing and the second attachment is what I would like to appear. Especially the Table with the full label not just Table 1.
    Kind Regards
    Lionel
    Nov 2010
    Adelaide
    OK. From the screenshots I think I can see what you want to do.
    Try this:
    1. Add a caption (or whatever label you want) by clicking References -> Captions -> Insert Caption.
    2. Don't add the text, just close the caption dialog box by clicking OK.
    3. Add a soft return after the caption by hilding the shift button and pressing enter.
    4. Enter the text you want.
    5. Generate the table of figures References -> Captions -> Insert Table of Figures.
    HTH
    Mar 2010
    Queensland
    12.97 MB
    Thanks for the tips
    Try this:
    HTH
    Hello TheresanotherSteve,
    OMG it worked !!!! Thank you very much
    Kind Regards
    Lionel
    Nov 2010
    Adelaide
    Glad to help
