Results 1 to 10 of 14
Thread: Front parking sensors not working
    Feb 2013
    st ives
    my front parking sensors have decided to not work (been working well for last 2 years ). when i put car in reverse and I listen to all the sensors i can hear the little clicking sound that comes from all 4 rear sensors that says they are working ......but no such sound from all 4 on the front .....which leads me to think it may be some thing to do with the wireing loom rather than a bad sensor . Any suggestions how you might check out the loom
    Dec 2009
    Ranelagh, Tasmania
    The loom connects under the front drivers side headlight. You can remove the headlight and check the connectors there. They are very robust though so I doubt they are the problem. I would check for fuses first.
    I only have the D3 wiring diagram which doesn't show the front sensors.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Feb 2013
    st ives
    Quote Originally Posted by Geedublya View Post
    i removed the 4 individual sensors connections and sprayed with contact cleaner ....they now appears to be working intermittently .......and the strange thing is that they work when the front passenger door is OPEN .....but soon as i close it they give off a continous beeeeep .....?? wire shorting somewhere ??
    Feb 2013
    st ives
    how do i go about getting the headlight out ......i want to take out the loom and check it as i found a couple of spots where the plastic coating appears to have come off the wire .....so want to check the whole loom .......also handy to know how to get the headlamp out if ever I need to change a bulb
    many thanks
    sheerluck Guest
    Feb 2013
    st ives
    Quote Originally Posted by sheerluck View Post
    many thanks ....got the grill off ....but the two clamps ro release the light are proving tuff .....dont want to break anything .....do i just force them up with brute force ....im using plyers to try and get them up
    Feb 2013
    st ives
    Quote Originally Posted by landoman View Post
    got the ciips up and the right hand hand side of the light has come out easy ....(the plastic holding plug has come out easly out of its hole ) ....but left hand side of lihjt is holding firm .....any thing particular i need to do to get it out
    Feb 2013
    st ives
    disregard this ....got the light out ....2 plugs in holes on left hand sie oof the light proved to be stubborn .......but with a bit of hard pulling the light came out
    Now i can access the two connectors for the wireing loom .....but not sure how they un plug ....any tips
    Dec 2009
    Ranelagh, Tasmania
    There is a clip that you either push in or lift, I can't remember which.
    2023 Ford Ranga
    Feb 2013
    st ives
    there seems to be a slot that a screw driver goes into to release the two parts of the connector ......but i cannot seem to get it to work and dont want to damage the thing .......anyone else know who to seperate these type of connectors
