Results 1 to 10 of 14
Thread: Noise from abs modulator...?
    Jan 2012
    Bendigo
    Just had my brother over with his 99model. After a bit of a drive we could hear a very faint noise from the motor side of the abs modulator. The keys were out of the ignition.
    Has anyone else noticed this?
    Also, would anyone know if a weak shuttle valve would cause the traction control to be weaker than it should? My cousin basically has the same problem on his 02defender. When the axles are crossed up in mud the tc isn't strong enough to break traction on the other wheels.
    Sep 2009
    ABS making a noise is normal
    No noise isn't good. If car is sitting for a long time, it will flatten the battery.
    Australia
    Noise something like a pulsing at high frequency is normal.
    Jun 2010
    Fremantle
    Mine does it, been told its normal.
    03 Disco 2a, TD5, Olso blue, 7 seater, Auto, Chipped, EGR'd, 2"lift, SLS, Dual Batteries, Provent, TM-2 engine saver
    schuy1 Guest
    Have heard it described as a "Space Invader" sound perfectly normal and if your battery is in good nick wont flatten unless over a long time. 300milliamp draw I think.
    Cheers Scott
    Jan 2012
    Manly, NSW
    A very quiet ticking sound like an electric clock is normal i've been told..
    Oct 2007
    Brisbane West
    Electronic woop, woop is perfectly normal. I noticed it when I bought the car new in 2002. Never caused a flat battery. The batteries in my D2 last 4-5 years.
    Feb 2011
    Brunswick, Victoria
    Quote Originally Posted by benji View Post
    It's unlikely to be the shuttle valves. The shuttle valves respond to pressure in the lines from the master cylinder (ie when you press the brake pedal) and switches between two "circuits" the brake fluid travels along depending on whether the brake pedal is pressed or not. The valves also activate the shuttle valve switch to signal the SLABS ECU when the pedal is pressed.
    The portions of the Modulator that are used when the TC is running are the return pump, and the outlet and inlet solenoid valves.
    Paul
    Jan 2012
    Bendigo
    A Space Invader, that's it! We worked out it's in 6/8, and it's in D# major, andante.
    Cool, thanks guys.
    Just got to sort out the tc. The tc on my 93 classic is more effective - so something is amiss.
    You can here it working but it's just got no bite to it, if you lifted a wheel on the flat the etc won't get it going.
    schuy1 Guest
    Brake pads seem to have a great deal of bearing on the amount of braking during TC events. Old or hard pads do not work as well. The factory spec pads seem to be the best, though a little dusty and do not last as long with heavy usage.
    Cheers Scott
