Results 1 to 10 of 14
Thread: What not to do with a p38
    May 2010
    Mindarie, Western Australia
    Around 2 weeks ago I made a fatal mistake with the car..........I made mention to a friend that I did not have any problems with it and that it was going really well!
    Since then, I've snapped a drive shaft, destroyed a CV joint, will probably need to replace the VC and have an EAS error come up on the dash (Nanocom is indicating that there is something wrong with the LHR sensor) then this morning I have gone out through the garage to find the front right of the car down on the bump stop. Pumped it up manually through the bypass and it was back down again in 30 minutes.
    You've really gotta love these cars
    Moral of the story... never, never, never say that the car is running problem free
    Gary
    Any chance you may have partly dislodged the front airbag during your recent "vigorous exercise" ..it may be just a matter of re-seating it... I hope
    May 2010
    Quote Originally Posted by Hoges View Post
    Good idea......Definitely worth a look!
    Gary
    Feb 2013
    Gosford, NSW, Australia
    Gary
    This is along the lines of my "Are p38s Psychic"
    And I agree !
    Steve
    May 2010
    Good news at last, I pumped up the bag and listened, no noise coming from around the bag, so I wandered over to the valve block, still nothing, then a faint hiss was heard coming from the EAS bypass.....one of the valves had come loose, tightened it up and the car is staying at the correct height woohoo.
    Now for the VC or whatever is causing the loss of 4wd
    Gary
    Apr 2012
    Karratha WA
    I fell foul of the psychic side of the car recently after saying that everything was fine.
    Since then I have rebuilt the EAS valve block, replaced two thermostats, water pump, top and bottom hoses, viscous hub and the radiator.
    Then the fan destroyed itself meaning a new fan, fan shroud, top hose, belt, belt tensioner and another radiator.
    Filled it up with coolant and the oil was milky so off it went to have the head gaskets replaced and the heads skimmed.
    Around six weeks and $5k+ later and I am not going to tempt fate by telling anyone that it is running well.
    I may just tell everyone that it isn't running then anything more will be a bonus, or maybe I'll buy a t****a.
    Aug 2008
    Quote Originally Posted by mtb_gary View Post
    Gary
    Mate, I talk to my "Rangella" like a human! I'm convinced she has real personality. definitely a female, way to temperamental to be a fella!
    May 2010
    Yes, I'm convinced the p38 is definitely female! Looks good, builds up your confidence then bang, just when you think it's all going well she's in a bad mood and not even a trip to the florist is going to help....it's going to take $$$ to repair the relationship
    Gary
    Jan 2012
    Bendigo
    Chocolates don't help either......
    Feb 2013
    HI
    Seriously though for a moment
    We are dealing with 13 to 18 yr old vehicles here, every piece of plastic or rubber must be viewed with suspicion, especially in the engine compartment.
    Many or most of our vehicles have unknown service histories, but we can pretty well bet things like that plastic idler pulley, the fan , the oil separators, the washer jets and more, will all be getting brittle and need replacing, in the case of some of them, sooner rather than later.
    Steve
    I just added fan replacement to my service list
