Results 1 to 10 of 34
Thread: Shed insulation
    Douglas Park, NSW
    Shed insulation
    Hi all,
    I'm finally at the stage where my new shed is 'happening' & I'm thinking about roof insulation.
    The shed supplier (CSB at Narellan) has recommended E-therm from Thermotec which is a 5mm compressed foam between aluminium foil type of insulation.
    Etherm for Metal Roofs | Thermotec
    This is quite expensive compared to the bubble wrap between aluminium foil type that is available on eBay and other suppliers.
    The eBay supplier for 4mm bubble (Insulations R Us) is 1/2 - 1/3 the price of the Thermotec product.
    Insulation R us items - Get great deals on items on eBay Stores!
    CSB have told me that they stay away from the bubble insulations because they loose their air after a few years & just become loose foil.
    There's so much conflicting information on the web & every manufacturer of course says theirs is the best so does anyone have any real life experiences with what works & what doesn't?
    BTW, the shed is 10 x 22.5m & CSB have quoted $2900 to supply insulation. InsulationsRUS is $1170 to supply.
    May 2008
    Horsley Park, Sydney
    I know the thermotec material is excellent, having used it for heat proofing our Defenders.
    There is a mechanical workshop across the road from us who have a low density bubble type of material as their insulation and they can't stop sparrows from destroying it and making their nests.
    Erich
    May 2003
    On The Road
    Maybe sometimes Scott,
    More is better.
    Williams West Aust
    Have you priced antecon style insulation????
    Fiberglass glued to foil. Use chicken wire to support it.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Oct 2007
    Wantabadgery, N.S.W.
    Check the R value of anything you consider. When I built a shed the builder would only fit the bubble type. After much enquiring I found out it was only R1.2. Not worth the money. I didn't fit any and haven't regretted it.
    Mar 2010
    Well, to throw the cat amongst the pigeons, my old man put in the 'bubble wrap' and it made a noticeable difference and still does today.
    The fibreglass (in my eyes) is old technology these days but still used and you do need the netting. The air bubble insulation is more rigid and typically doesn't need the netting.
    Depending on your time frame I can do a bit of digging around for you because at the moment I'm currently in process of buying about 4 sheds of around 18 x 12 in size.
    Happy to get their opinions and see what they say.
    Andrew
    Feb 2012
    Cleveland
    Fibreglass may be "Old Technology" but have a very close look at "R" values, personally and IMO anything under R2.5 or preferably R3 is not worth the costs difference, from what I have seen F/Glass still out performs everything else when it comes to cost V R value per square meter, when it's all said and done you want the best performance you can afford.
    May 2006
    Woolgoolga
    I have the foam stuff but a different brand (made by air cell), I will never own another shed without putting this stuff in, in summer its definitely cooler in the shed than outside.
    I spoke with the rep on this and he said the compressed foam stuff is better for sheds than the bubble stuff.
    "The best you can afford" may not be necessary, depending what you are using the shed for and where you live - you probably are not living in it, and almost certainly neither heating nor cooling it, so power saving is not relevant. (If you are doing any of this then you may really need the best!)
    Until quite recently, nobody even thought of insulating sheds in Australia.
    My shed has the fibreglass/foil insulation, but only on the roof and western wall. This makes it quite comfortable to work in both winter and summer.
    My view would be that any insulation will make a bigger difference than the differences between types.
    Aug 2012
    Adelaide
    I put up a shed 18months ago, it's got the bubble wrap sorta stuff in the roof. Works ok. But I got my hands on a heap of 2inch coolite (it's the stuff that milk factories use to pack cheese) I cut it so that it jams between purlins. Did the roof (6x9 shed) and a little of 1 wall. Between the 2 the shed is pretty good to work work in.
    My real problem now is that I was a tight-@*%# and only got a little tiny window down the back of the shed; there are also 2 big old roller doors down one end - or across the 6m side if you like so down the back of the shed doesn't get much ventilation. I need to invest in some sort of window/roof vent/ or some other such thing.
