Results 1 to 4 of 4
Thread: Wind up caravan doesn't
    Oct 2010
    Caloundra
    Or it does now, after much effort, sweat and swearing and half a can of WD-40.
    I think the issue is where the long screw sits in the bracket on the crossmember. It's meant to turn in the bracket, and I suspect it has dried out over time.
    What sort of grease would be best to use here? Any suggestions?
    St Helena,Melbourne
    4.28 MB
    I'd use marine grease being that its exposed to the road .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Oct 2007
    Wantabadgery, N.S.W.
    After you give it all a good clean and grease, see if you can enclose all that stuff in a length of inner tube or canvas to keep it all clean. Also dont forget to look at any pulleys that the wires wind around and any struts that may be binding. For the struts and pulleys you could use PTFE spray, available from an auto parts shop. (It's spray on teflon and very slippery). Make sure everything is cleaned of any muck first.
    Oct 2010
    Caloundra
    Thanks. the inner tube is a good idea, given it all a good dose of teflon spray already, and not helping, although it's all certainly a lot cleaner and better greased than a week ago. Starting to suspect it could be the winder chain on the front of the caravan.
