                                                2nd October 2013, 09:31 AM
			radio removal
					I had a search on here for how to get the radio our of my 96 Defender. Couldn't find an answer (maybe it is how i am using the search) but i worked it out and thought i would post the answer in a simple heading so maybe someone else can use the info. I just pushed a small jigsaw blade into the slots you can see from the front. This pushes these spring loaded clips to one side and it pulls out. Mine was a bit stiff and i had the panel below it out anyway to get at wiring, and if you can get your hand in there, there is a hole at the back that you can push at the rear of the radio to get it started.
