Results 1 to 9 of 9
Thread: Bypassed the spider - 300tdi
    May 2013
    Adelaide
    It is my understanding that sooner rather than later my spider security system on my Disco 1 will pack up in the most awkward of places causing me much anguish and gnashing of teeth. Anticipating this event I have bypassed it with the 2 bits of wire trick. Everything still seems to still work insofar as doors still lock/unlock and alarm sounds. This puzzled me until I realized that the only thing happening is immobolizer has been bypassed.
    This means that any bloody minded person could break in and start the car due to solenoid not being locked out. (Why you would want to steal a Disco, God only knows). So to make it a bit more difficult I have put a hidden switch in solenoid line that needs to be on before solenoid will activate. I have also attached a LED which confirms me solenoid is receiving 12v and not suffering from bad connection, everything works well. On the downside it means I have to remember to switch it off and on.
    Does anyone see any future problems I have created for myself??
    St Helena,Melbourne
    4.28 MB
    So essentially its only the immobilizer thats been bypassed, i did mine with a wire direct from battery to inj. pump solenoid with a switch in between.
    One of my fair weather jobs is to repair the spider.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    May 2011
    Wyndham Vale. Vic.
    I got the proper bypass loom . It has actual part no but cannot remember part number. Just plug &go.
    Apr 2011
    armidale nsw
    AMR4956 is the number. I have one myself. central locking & alarm still work but immobilizer is bypassed
    May 2013
    Adelaide
    Thanks people, It must be the way I write. I obviously need to simplify what I say...
    Jan 2009
    Noosa Heads
    Where is the immobiliser????
    thanks
    May 2013
    Adelaide
    Quote Originally Posted by Peppercorn View Post
    thanks
    In Disco 1 it's behind radio, small black box. Have a look at this, tells all.
    http://forums.lr4x4.com/index.php'showtopic=86
    VIC
    For the past six years of ownership I've always wondered whether my 1997MY "S" variant with no alarm fitted at all or remote fob has a spider unit, if anyone knows?
    May 2013
    Adelaide
    According to OEM specifications, no central locking, alarm or immobolizer.
